I thought it was just me having the search issuesHope this fixes my issues with address and poi searches...
I have the update. I just checked tailgate opening from console, works fine.Well... since the update, I can no longer open the tailgate using the console button inside the cab...
Can one of you check yours and confirm it works for you? So far this is the only issue I’ve found.
Yeah, this is what it was. What threw me off if that I’ve had zero issues, and this just happened right after the update. Removed the overhead console, reseated all the connectors and voila, all is well (all my overhead lights were not working either. Found that out after it got dark).I think there have been some with a loose connector in the overhead console.
I saved them as well but does not show any infoI save my favorite teams on my last few radio presets.
I think this is new but not sure... when you're looking at the 360 degree camera, if you have a front door open, it turns that section/camera black now. It also shows the running boards deployed/retracted in the 360 camera view. Maybe I've just never noticed these before, not sure.
Yeh, that’s the way it is. If a door is open the sides are black, if tailgate is down the rear is black. When these are open obviously it changes the camera position therefore going black.I think this is new but not sure... when you're looking at the 360 degree camera, if you have a front door open, it turns that section/camera black now. It also shows the running boards deployed/retracted in the 360 camera view. Maybe I've just never noticed these before, not sure.
Not able to. Obviously would require the correct mirrors with cameras and front camera. Disassemble parts of the truck, take dash apart to replace, reprogram the 12” screen and so on. It may be able to be done for a very large sum $ but I bet no one is willing to do it!are you able to add the 360 view? Or even just the front camera only and have it show on the 12.1 display?
All it said was system improvements or something like that. It didn’t list anything. The top card issue appears to be fixed. The USB intermittent connection issue seems fixed. Phone still goes back and forth between phone and truck if you try to call too soon after starting your truck. If the nav is selected on the split screen it wont default to the actual map, you have to swipe right, still. Sports favorites don’t really work right.
Ram, feel free to contact me so I can tell your engineers what’s wrong since you still can’t figure it out.
I don’t know why I’m frustrated with this truck so much, it’s just stupid little crap like 2 software updates in and it still isn’t right. Brakes squeal,A/C sucks, HVAC programming isn't right. I still love it though, super nice ride for sure.
The update fixed my issue with the system not retaining my top card. I now have my navigation up when I start the truck. It does go to favorites as opposed to the map but I'm OK with that. Haven't had a favorite pop up yet to see if there is any change with the notification.
