MitchM
Thanks+19.1 Offset
77.8 Center Bore
6x139.7 (6x5.5) Bolt Pattern
Thanks+19.1 Offset
77.8 Center Bore
XLAre those 305s lt or xl?
I need to move over to the toyo's - these ridge grapplers are ridiculous; noisy and vibration at 65-75.
Won't do anything about the noise, but have you had them road force balanced? Had that same vibe issue with the Toyo's until I had it done and now it's smooth at all speeds again. Discount Tire runs a little over $100 to do a set of four, at least in Orlando.I need to move over to the toyo's - these ridge grapplers are ridiculous; noisy and vibration at 65-75.
Probably a stupid question, but why didn't you just get the defenders in the stock size determined by manufacturer to be best for the vehicle? I'm trying to decide if it's worth going slightly bigger for just the look...doesn't seem like there's any other benefit and I definitely don't want to worry about rub. What was the difference your wife noticed? Ride quality, noise, both?The tires came in early so I got them installed today.
These are the Michelin Defender LTX in 305/45/22’s.
The ride home was smooth and quiet and even my wife noticed a significant difference as a passenger. I slipped the tires once intentionally compared to 2-3 times that the old tires would have slipped unintentionally. There was some minimal rubbing at full turn, (in Aero mode), but once I was out of the tight parking lot, it never happened again. I'll look it into more once it stops raining.
Exactly, I went with the Toyo's OC ATIII 305/45 r 22 mostly to get more sidewall and the bulge has protected my Rims on a few occasions where a tight parking lot or drive thru would have ended in curb rash on the rims before.More sidewall means a smoother ride and the bulge helps protect the rim from curb rash. I’ve also learned that when a tire doesn’t last it’s intended mileage, bump up in size until they do.
Case in point, when Ram trucks with the V10’s came out with 245’s, you couldn’t help but spin the tires at every stop and they wouldn’t last more than 8k kms a set. I bumped up to 295’s and got 105k kms out of a set of BFG AT’s.
On the Rams with the Hemi and 392 gears, my tires spin a lot and I go through a set every 25- 30k miles. I’m banking that going to a wider tire will provide more grip and longer lasting tread.
That looks an offtly like Pooler gaMy local car wash is a perfect example of crap we can’t avoid. They have a straight lane that is closed off 90% of the time forcing everyone to navigate a tight S curve. I nail it about 80% of the time but those other 20% I either rub the front or the back.
Nice man, lived right off that road for 4 years. Miss Pooler. And Savannah for that matter. Especially downtown during Ga football games!That’s because it is Pooler![]()
I have been driving around in the snow past couple days here in the PNW with these. They work really well. These tires are Tri Peak rated. Like most tires, Ice is still ice.Anyone had the Toyo ATIII in the snow yet ? I travel a lot of snowy highway and looking for the best tire.
Where did you buy the tires?Picture was taken in OR1. No lift, spacers or links installed - all factory original. I’ve been contemplating the BDS 4” which retains factory air settings, but so far very happy with the 305/45/22’s on factory ride height so may keep as is.
