How to: Add Adaptive Cruise Control, Lane assist, FCW & Auto Hi-beam to Ram 1500
kldake.kd
That's normal. Did you enable the rain sensor in AlfaODB? That's why they think it is there. Then the rest your BCM which is
Question: is this the correct rain sensor part or auto wipers or is this humidity only?
68298468AA
I see some conflicting info on the hdram forum about this - where someone with the same situation used a different part number instead of this one.
vincentw56
68298468AA
Everything I see from searching that part number say it is.
Jimmy07
Honorary Site Supporter
68298468AA
68298468AA is humidity only (dual zone ATC description means humidity):
kldake.kd
System works perfectly now
Thank you to everyone that has contributed to this project. You guys rock
Cmassey31099
Need some guidance here… I have the rain sensing wipers in my truck from factory so I think that means I may already have parts there but I really want auto high beams is that possible with just changing it in alfaobd? Is there anything else I can also just change in Alfaobd that would give me any other options? TIA
vincentw56
You should be able to enable auto high beams.
tdb0021
Denver, CO
Yes, you can enable it in Alfa an it’ll work for you. No modifications necessary.
Paco
I did Auto Highbeam yesterday with jimmy help.
The only problem I had, was the Auto Highbeam did not show up in the uconnect for a couple cycles.
Jimmy suggested I cycle the radio on and off a couple times, and then it showed up.
Cmassey31099
It worked, also put on my tailgate ajar. I also used JScan, much easier than alfaobd in my opinion
Well I have it in my radio menu, when I flip the lever toward it says auto high beams enabled but they don’t come on at all. Anyone know if I missed something when making changes? I swapped out my auto dim mirror for the rearview mirror with the camera. That was plug and play but could that be an issue?
cskindt
SW IA
Not necessarily.
I enabled the auto high beams with my auto-dimming mirror and it worked, then later changed my rear view to the digital rear view and my auto high beams still worked without issue.
vincentw56
If you got that message, it worked. They can be a little sensitive to light so try a really dark road.
Jimmy07
What do you have 2014 cbc..auto high beam location set to?
Jimmy07
IRCM
That setting is only if you have the DASM for FCW and adaptive cruise. You are using the mirror with camera for high beams, so try ecc_AHBM for that setting.
Cmassey31099
I’m out of town for work till Thursday so I’ll give it a try then appreciate the quick response!
wsolarczyk
If your truck came factory equipped with FCW but not ACC, you need the following: (see attached file for additional information).
HCU: 68415320AA ACC w/Stop and Go - $265.55
ABS Module: 68436462AJ Adaptive Cruise Control w/Stop and Go], [Adaptive Cruise Control w/Stop and Go] After 06/06/2018 - $200.64
ACC Button - 68309592AD SWITCH. Speed Control. Right. = $57.05
Lane Keep for 2021 RAM
Requires:
Center Stack 68312620AG – $468.60
Hello, and thank you for a very nice instruction. This is awesome. Can you point me into the right direction of finding which center stack do I need for my 2022 Laramie with 8.5 U5 unit if I don't want to upgrade to the 12" one. I want to do the price comparison. Also, shine some light if you can. If I don't want to add AAC but only Lane Keep, give that my truck has FCW and Rain sensing wipers already.
Thanks,
St-na
Houston
Thanks,
p.38 Message from Jimmy07, You can use search function, pretty easy.
Jimmy07
Thanks,
Is it an 8.4” radio with navigation? If you post a pic of your current 8.4 center stack, I can tell you which one you need for LKA.
