Here Is Everything You Need To Know About The 2023 Ram 1500 (DT)!
Jray22
No more non-hybrid Hemi. No more fender flares on Laramie. No more inverter/115v outlets except on premium trim levels. Totally revamping content on the best selling trims. And yet, the prices are still going up like a rocket.
I felt like I overpaid for my '22, but now that I see the '23 order guides I'm happy as hell that I bought when I did!!!
Yea, it’s completely out of control and only getting worse. Coming from a GM I knew I didn’t want another so it was between a Ford or Ram. I was all set on ordering a 23’ Ram But once I was saw the spec sheets for Ram and Ford I decided to find a 22’. You think Ram is bad look at a Ford! A XLT very well equipped is now 70K.
Switch22
Where are you guys finding the spec sheets for the 23s? I see the build configurator online is still for 22s.
Jray22
Certain dealers have it on there Website. I just did a google search and found a dealer in TX that it available online. Your local stealership has it already as well. I just did a quick search for the below. You’ll just have to convert it to USD.
jimothy
5thGenRams Supporter
Atlanta, GA metro
No fender flares? That’s silly. They’re a little thing that makes the truck look so much better. And they can’t use the chip shortage as an excuse. Bizarre.
HemiDude
Ohio
I agree. The factory flares were one of the (many) reasons I was looking at Laramies when I bought mine. I know the BTS has them, but there were none around here at the time. This kind of crap makes very little sense, and seems like an odd way to save money, unless they just want to phase the Laramie model out all together
Eighty
Moderator / Dream Killer
It could just be a supply issue. Chips aren’t the only things they are having trouble getting.
Eighty
Rumor is that all colors are available for order again
CalvinC
Colorado
Not standard on the 23 Laramie as of 12/19/22
Per the 23 website configurator this is technically true but if you add practically any option - 33 gal tank, level 1, bed utility, etc. - the configurator is adding it per the render anyway (when it works).
Steven666
Question. If Ram is only offering the 5.7 Hemi eTorque. With Engine start/Stop. Can this feature be disabled? It can on Ford and GM. Just curious as today I was told I can’t Order the 3.0L diesel either and the only option was the V6 or the eTorque for the 2023 Rebel.
I can disable it in my 22 Limited. A button on the lower dash turns it on or off.
crusher
st-jean quebec canada
just check for fun, and in canada the 2023 laramie looks to still come factory with flares and also digital cluster... per ram website, wonder why its different here
crusher
after digging more the new cluster is not standart anymore in canada laramie, but are still standart on lower trim like sport and rebel, thats very strange
but the flares still look to be there on laramies...
Eighty
Based on the starting MSRP prices, it would appear that the Laramie is a lower trim than the Rebel.
Kumba1010
Even on the US website, 2023 Laramie is shown with fender flares. Picture taken of a group member's 2023 Laramie though doesn't have flares
