Hello,
Same issue every day! 22 Laramie
Have taken into dealer multiple times day after purchase even. They state no codes stored and think it’s a Uconnect issue.
Is any also experiencing these pop ups on the screen?
Service Notification - Battery
“Battery Alert”
Your vehicle's Battery requires attention
Press Call for assistance.
Service Notification - Tire Pressure
Low Tire Pressure
Your Tire Pressure is low.
Or in the app I get these errors daily…
CHARGING SYSTEM FAILURE: if the symbollights up when the engine has been started, this indicates a charging system failure. Contact the Customer Care Network as soon as possible.
EOBD/INJECTION SYSTEM FAILURE: in normal conditions, by turning the key to MAR (driving position), the warning light turns on, but should go off once the engine is started.
Traffic wardens are authorised to check that this warning light is in working order. Comply with the regulations in force in the country in which you are driving.
AIRBAG FAILURE: by turning the key to MAR (driving position), the warning light turns on, but should go off after a few seconds. If the warning light stays on, this indicates a fault in the air bag system. On some versions, the display shows a warning message.
See attached. They go on and on, pretty concerning and really questioning the service techs as they say nothing to worry about. When it comes to powertrain and airbags (safety) especially as my family vehicle I am worried, curious if any of this is related or if others are experiencing similar notifications.
Thanks!
This is my 3rd Ram in the last 4 years hard to say this but quality has dropped significantly.
View attachment 143477View attachment 143478View attachment 143479View attachment 143480View attachment 143481View attachment 143482View attachment 143483View attachment 143484View attachment 143485View attachment 143486
