Toperz
Stratford, CT
Hey guys. I have problem to find screen module(silver box) everywhere I looked is ac/heat module. Those parts listed in past are discontinued and it says its replaced with screen only now.
I'm gonna move from 8.4" non-navi to 12"non-navi.
Thanks
Bsaylor
Thanks
Toperz
Stratford, CT
What is difference between those? Price of course but what is the rest.(specifically 12"). Is those saying up to 10/2019 or11/2019 gonna work in 2021 Ram?
Thanks
Cmassey31099
So the last thing I’m waiting on (the bezel) is coming in the new few days. I have the module, screen, rubber top piece, LVDS cable, repinned hookup, gateway bypass, and Bluetooth OBDii. Is there like a written step by step somewhere on exactly how to do the replacement? Thanks
MannymanX
5thGenRams Supporter
AzZona
Cmassey31099
How have you all programmed using AlphaOBD? Did you use windows? Your android phone? iPhone?
Anyone try using windows through a MacBook?
I only have iOS products so I may need to get something alphaOBD can work with.
Jimmy07
Honorary Site Supporter
You can use Jscan if all you have is iOS. It has the same settings needed to change as AlfaOBD.
Toperz
Stratford, CT
Hello all.
Did anybody successfully swapped units in 2021 BigHorn? If yes please pm me.
Thanks
MannymanX
AzZona
Hello all.
Thanks
Basically all of us are BH and Laramie owners.........
Cmassey31099
So I am using android version alfaobd.. do I have to put my truck in Acc or run? I keep getting this error when I try to connect to the BCM
Jimmy07
Ignition off, acc, or run- it doesn’t matter. Just click continue.
Cmassey31099
Ok so I made the changes. My truck has been off the whole time. What’s next?
Cmassey31099
I see the buttons on the new screen lighting up but nothing on the screen.. do I have to pull a fuse to let it reset or?
MannymanX
AzZona
Unplug the battery and let it sit for a few minutes... After you reconnect it, it might take a few hours for all the feature to come back live on the screen, but you should get a display on the screen.
Cmassey31099
Everything seems good. Putting the screen into the bezel.. looks like I need 7 screws to attached the screen with the bezel.. anything cheap I can go get tonight? What did you guys use
MannymanX
AzZona
Yes, I went to Lowes and got a pack of 8 - M5 screws for the screen. just make sure they are short enough...
