Str8Ripon
- Mar 24, 2020
Okay, thank you for the explanation, makes more sense. I will add the travel link with the instructions previous page, figure out what Sirius needs from me to activate the subscription, and should then be good to go.Travel link and traffic alerts are SiriusXM services, and have nothing to do with the missing WiFi/Bluetooth antenna (green connector on the radio module) or the cellular antenna (pink connector on the radio module). You already have the antenna necessary for the three SiriusXM subscription services, which is the mustard yellow connector on the back of the radio module.
The green connector is for WiFi/Bluetooth antenna, which is really only needed if you are activating the WiFi hotspot, or are Bluetoothing your phone to the radio, and having signal issues. The pink connector is on the radio module is for 4G, which in used for (but not necessarily needed) Sirius guardian services.
Traffic alerts is part of the travel link app, so once you enable the soft key on the radio, and you have an active subscription to them through SiriusXM, you’ll be able to use the app on the radio.
Thanks again!
