vincentw56
- Aug 5, 2020
Yes, I had installed the HCU and ABS over the weekend and it is working. Now I do have the issue of the parking brake light on before I installed the other items. Maybe the ABS wasn't fully initialized. Should I remove the DASM reset the settings and take it in to have that fixed first? I have checked the wiring several times to make sure everything is in the correct spot.Just the basics- correct abs and HCU modules installed, and abs initialized? DASM is calibrated? Make sure Linbus wire is in the correct location on your harness. If you had auto dim mirror before, does it still function?
