How to: Add Adaptive Cruise Control, Lane assist, FCW & Auto Hi-beam to Ram 1500
I have already seen someone add this to their 1500. From what he told me, it has nothing to do with the BCM, he said the mirror and the CHMSL are direct connected. Not sure if this helps you at all.
Yes, it’s been added to the 2021s successfully, but doesn’t work 100% correct (auto dimming feature is lost for regular mirror mode). It’s definitely a bcm/settings issue for those with pre-2021s. The guy that’s going to be helping is going far beyond the settings changes, and is going to be looking into the differences of lin bus messages being used on the fully functional option vs messages used previous BCMs. I’ll be installing it on my 2017, and he’ll be installing it on his 2015, and hopefully get it to work correctly for any other year.
I need to double check, but I think the wiring for the CANBUS is reversed in the instructions. I will look at my extra connectors and let you know. Outside of that, it was great. I had no issues with installing anything else. It is easy if you know how to bleed brakes. That would be the biggest hurdle for people who have never done it before. Even though it is easy to do. I am going to dealer this Friday to get it calibrated.
did you get it activated successfully?
Alright, chalk up another successful install. Everything works perfectly. Well, I haven't been able to test the front collision avoidance yet.
Alright, chalk up another successful install. Everything works perfectly. We'll, I haven't been able to test the front collision avoidance yet.
Good to hear. I need to stop dragging my feet and order the correct HCU.
Easiest way I think to see if FCW will react is to set it to far, and wait for someone to start slowing in front of you to make a turn. Mine will usually start beeping at about 3-4 truck lengths if they haven’t gotten completely out of the lane by then and you aren’t on the brakes or slowing significantly. I don’t run it with the braking on so I can’t speak as to how quickly it reacts after the initial alert.
I'll try it and see.
Awesome! Thrilled to have someone else complete this from scratch like I did. Check out comma.ai when you get the chance. My truck completely drives itself on interstates now. Very very nice to have.
I have yet to see my FCW work. Mine is factory installed with pedestrian. I have it set to far. I set up some large boxes in my driveway and it just plowed them over. No braking, no warning. I kind of want to see what it is like, so it doesn't scare the crap out of my the first time.
Oh, yeah, I'm checking that out for sure. I've been following it. How hard was it to adapt the harness?
I might setup a foam wall and see.
I’m not sure how well it reacts to a totally stationary object. From what I understand it uses algorithms to compute closing distance, time to collision, etc, based on two moving objects… I’ve had it go off several times either while coasting up on someone that was slowing to turn, or if someone suddenly slams their brakes and I don’t react as soon as it thinks I should. I’ve even coasted towards stoped traffic at a pretty good pace and it hadn’t alerted me before I got to the edge of my comfort zone and hit the brakes on my own.
I’m thinking about having someone throw a body pillow out in my path of travel to see if it’ll pick up on that thinking it’s a pedestrian entering my path.
Reading the service manual states it should track stationary objects.
The harness is very simple to make. If you can make the one for the DASM, you can make the one for comma. I highly recommend it.
As for the FCW, I’ve had it go off on me before, but I have the emergency braking turned off, because I don’t want the truck slamming the brakes for me. It did that once when I was backing up and had hot coffee in my hand. It was not pleasant
If it does, it sure has more confidence in the trucks ability to stop than I do. I’ve never had it apply the brakes, but I’ve heard it actually does a pretty damn good job getting stopped.
It's an interesting read about all the things it does even before I decides to stop.
I had only one or two times this warning on my dash, not sure if it's 100% avoiding accidents, but it gives some help.
From Your very first post thinking about comma.ai, checked discord and spoke with comma.ai support. Since they do not support RAM officially and all responsibility is ours, I am little bit concerned.
To each their own... I could see someone being hesitant about it. The code hasn't been upstreamed yet for Ram - which will happen soon. Running this kind of development hardware does not worry me, especially since I know how the safety features work in both openpilot and Ram. The safety standards are the same across the board for non-supported vehicles and supported vehicles. I've had several multi-hour drives where i haven't had to intervene or touch the wheel all. it's really quite amazing.
So I set my FCW distance to medium and it went off when I was coming up on a vehicle that was turning. It didn't apply the brakes, but that's because they turned. So it seems to be working too.
Hello Gentlemen, I'm impressed with all this work!
I have a question for you, I have a brand new ram trx that because I wasn't able to build myself it didn't come with adaptive cruise control, but it has all other features, this is what I actually have: (see below in yellow color)
@Stepanchina I think I saw you mentioning you got lane keep assist working just changing config? (no ACC)
@Jimmy07 see attached the stock system ID parameters.
@Stepanchina and @Jimmy07 I think I just need to order:
And some config over AlfaOBD?
What would be the changes? those published by @tdb0021 ?
You need to enable/disable the following:
Auto Highbeam: Yes
Cruise Control Present: No
Collision Mitigation System Present: Yes
Forward Collision Warning Present: Yes
Lane Departure Warning Present: Yes
Full Speed Range Forward Collision Warning Plus System: Yes
Type of adaptive Cruise Control (ACC) system present: ACC with stop and go
Auto High Beam Module Location: IRCM
Forward Collision Warning CSM Present: Feature 2 – 3 Option
Forward Collision Mitigation Braking CSM Present: No
Auto High Beam CSM Present: Yes
Lane Departure Torque CSM Present: Yes
Lane Departure Warning CSM Present: Yes
LDW On/Off CSM Present: No
Forward Collision Warning (FCW) Switch CSM Present: No
Forward Collision Warning Single Setting (Warning and Brake) CSM Present: Yes
ACC Adaptive Cruise Control: Not enabled
ACC/DASM Adaptive Cruise Control/Driver Assistance Module: Enabled
In addition to the TRX base equipment
A6E TRX Level 2 Equipment Group 7
*YL Leather Trimmed Bucket Seats
CAH Ventilated Rear Seats
CAJ Ventilated Front Seats
CAK Rr 60/40 Folding Split Recline Seat
CMA Heated Front Seats
CSV Driver/Psngr Assist Handles Wrapped
CTH Luxury Front Door Trim Panel
CUE Rear Underseat Compartment Storage
CVT Full Length Prem Upgraded Floor Cons
GFA Rear Window Defroster
GNC Sun Visors w/Illum Vanity Mirrors
GXD Remote Proximity Keyless Entry
JEK Premium Wrapped I/P Bezel
JHC Rain Sensitive Windshield Wipers
JKR Remote Tailgate Release
JPZ Heated Second Row Seats
JRS Power 4-way Passenger Lumbar Adjust
JTE Power 8-Way Driver/Passenger Seats
LB1 Front Door Accent Lighting
LB2 Rear Door Accent Lighting
LBE IP LED Ambient Light Pipe
LEM Exterior Mirrors w/Memory
LEQ Driver Seat Memory
LEV Radio/Drv Seat/Mirrors/Pedals Memory
LPL Pick-Up Box Lighting
MNK Body Color Door Handles
NHS Heated Steering Wheel
RFX Wireless Charging Pad
SC1 Leather/Suede Flat-Bottom Strg Whl
XAK Surround View Camera System
XAM Power Adjustable Pedals w/Memory
XAN Blind Spot and Cross Path Detection
XBM Remote Start System
XGD Universal Garage Door Opener
XH4 Parksense Ft/Rr Park Assist w/Stop
XHC Trailer Brake Control
Thank you!
Gaston
