How to: Add Adaptive Cruise Control, Lane assist, FCW & Auto Hi-beam to Ram 1500
Got the switch installed and made the bcm changes. However now I have no ACC, no FCW and no standard cruise, along with lights and messages telling me so. I am not pulling any stored codes, so I guess I’ll keep looking around for something I might’ve missed. I did get it to pop up once and say ACC ready, but then it went away when I did something.
Thats why I went with the windows version, Can use any BT enabled laptop or my Surface pro.
I don’t have a windows pc anymore. The one I had for tuning my Titan finally died and I never bought another one.
Oh boy..... hoping there is just a missed setting of some sort.
@Jimmy07, any ideas? The only procedure I’m not seeing in the abs is the longitudinal sensor calibration.
I double and triple checked them all. But you never know. Probably should’ve left things alone until after I take it in on Thursday since it died on me again today while driving.
The truck just died on you while driving today? Damn, that isn't a good sign!
Did You upload Your system ID, prior to new settings?
Not the first time. And I’m not the only one it’s happened to. Luckily it has just been on the base so it was low speed low traffic. No codes, no warning lights, nothing. Engine just shut off while coasting to make a low speed turn. Guess now I have two issues to have them look at.
I’ve got a copy from before I made any changes pertaining to any of this. Worst case I can have the dealer do a restore.
Can you send me your current bcm system ID as a google drive link? I’ll take a pass through it real quick.
Yeah, give me a few minutes and I’ll hook back up to it and pull it.
No change this morning other than my settings showed back up in Uconnect. The standard cruise, ACC, and AEB are all still disabled. If I change the settings for the FCW in the Uconnect, within a couple of seconds it beeps and goes back to off. Since the part number for the HCU are the same on my truck as well as the limited I looked at recently, I wonder if the ABS module itself is different on the 21's and they all just use the same HCU?
@tdb0021, is the ABS module a fairly simple swap, or does it require bleeding the system as well?
Keeping our fingers crossed. Nothing bad, like died truck happened with tbd0021, during his project. Hope when issue is solved You will share
Keeping our finger crossed. Did MaythemMoor checked Your current bcm system ID? I hope You will share final system ID with us. Did You also install new center stack with lane assist button, or only ACC?
Jimmy07 looked over my BCM settings and everything looks as it should and there are no faults stored in the modules that correspond to the lights on the dash. I have not installed the center stack yet, it shouldn't affect the ACC side of things.
Yes, I understood it shouldn't. My center stack is expected this week, just thinking to do that part of the project first, there were no problems shown on Your track when LKA settings has been change in BCM. Basically, if You change Your ACC BCM settings to original, You should have Your track back to operation with possible ACC button fault shown. Or not? Just a temporary solution, before the reason of the troubles found.
With anything - it'll just take a bit of trial and error before we figure out the procedure. I figured something along these lines would happen.
ABS module swap is easy and can be done rather quickly - no bleeding required. its the HCU that is more labor intensive. Do you have any ABS error messages? Check each module for active troubles. I remember seeing "acc valves not calibrated" when i made my HCU/ABS swap. If you connect to 2016/2017 jeep cherokee under the adaptive cruise control module you can pull codes from the DASM.
I'll see if I can connect to the dasm, I'm not getting any codes from anything else so far even though the warning lights are on. I should have the dealer run the VIN on the Limited and see what it shows for a part on the ABS module compared to mine, perhaps they are different.
I'm hoping reverting the settings back will undo the errors, I will try that today.
