- Apr 11, 2019
Yup, pin 12 is white, canbus c+.Meant 21/22,and I think you've guessed correctly again sir. I pulled the yellow and the white next to it if I remember correctly. I'll dive back in shortly.
They’ll come back after a while. It’s normal.Jacked something up I guess. Lost back up cam, passenger seat climate controls, and cargo cam buttons on the screen. Ugh...
When you unplug you radio you will temporarily loose those apps it take a couple of hours to come back, or use Tazer DT to reboot the radio that’s what i did my Rebel used 21 & 22 it’s a 2021 yearJacked something up I guess. Lost back up cam, passenger seat climate controls, and cargo cam buttons on the screen. Ugh...
Yes, you would connect to the 2017 radio navigator module instead of the BCM. Reset ECU is in the list under active diagnostics.Was there a radio reset available within alfaobd? Been looking for a minute without success. Looking to test before putting back together.
I believe as long as it’s with nav it’ll workDid some digging in here and could find if this works on the 8.4 with nav. If so is it pins 21+22?
Sorry I can’t help with AlphaOBD. I used a TazerDT to activate.I just read the whole post and I'm a bit confused.
-Bought OBDlink MX+
-Bought Infotainment SGW Bypass
-Bought pins from mouser
-Bought RCA Video cable
-Bought Camera
-Will get alphaobd as soon as I figure this out.
What exactly do I have to change in alfaobd to make it happen?
thanks for the help!
2020 Rebel 12 Level 2, 12" U-Connect
I can switch to Tazer DT. I went with AlfaOBD beacuse, for what I've read, there are not too many things that can be done with Tazer DT. Or is it the same thing?Sorry I can’t help with AlphaOBD. I used a TazerDT to activate.
Once connected to the body computer, go into car configuration change and change VehicleConfig 1: CHMSL camera to yes, and that’s it.I just read the whole post and I'm a bit confused.
-Bought OBDlink MX+
-Bought Camera
i used Tazer so i have no info on alfa , with tazer i changed my tire size & tire pressures also activated front camera tazer does offer a lot of other stuff, idle up to help winch power , turn fan off to forward hi water.I can switch to Tazer DT. I went with AlfaOBD beacuse, for what I've read, there are not too many things that can be done with Tazer DT. Or is it the same thing?
AlfaOBD is the more powerful of the two tools for sure, though you can do quite a few things with a TazerDT.I can switch to Tazer DT. I went with AlfaOBD beacuse, for what I've read, there are not too many things that can be done with Tazer DT. Or is it the same thing?
