I did the links when truck was new only 600 miles but no problems yet, I did a lot of research some other guys on here ran stocks up to 25-30,000 miles with stock you see UCAs with no problems, it is a little tight the angle of the UCA but it doesn’t hit anything I’m just gonna try running it if I have to replace them or replace them but I have no rubbing with 295 6020 tires. I only keep my truck still about 30 35,000 miles and don’t do any off-road Ing so I’m hoping I will be fine!What is everyone's take on the Daystar spacers and links with the 2020 Limited with the OFF Road Package? Been hearing clearance issues? Replace UCA a must?
Same no problemsI did the links when truck was new only 600 miles but no problems yet, I did a lot of research some other guys on here ran stocks up to 25-30,000 miles with stock you see UCAs with no problems, it is a little tight the angle of the UCA but it doesn’t hit anything I’m just gonna try running it if I have to replace them or replace them but I have no rubbing with 295 6020 tires. I only keep my truck still about 30 35,000 miles and don’t do any off-road Ing so I’m hoping I will be fine!
Without the daystar spacer your ride is going to be more bouncy on the front end.I have been reading a lot on here about the best options for leveling with the air suspension. I have a 2020 Limited and despise the 22" wheels, but love the vehicle otherwise. I am having a hard time finding a installer to do the links/spacers because they don't want the responsibility of anything going wrong and there isn't any "premier" resellers supporting this combo. Rough Country does have a new bracket that I believe essentially does the same thing as replacing the adjustable links people use. LINK
I may try this for $30 - End goal is to get 35x12.50 and 20" wheels under it. I also don't see it mentioned much on here but the offset is also a large reason why some people "rub" and some dont. A large offset that some people like changes the geometry of the wheel travel within the wheel well.
I am not an expert, but have had a RAM for the last 10 years and done a lot of research through forums and other resources. I really respect and enjoy the input from everyone in this community.
links because you can adjust them up and down to your liking I raised the rear and the front of mine have about 3/4 of an inch rake with the taller tires and a leveling kit I gained about 4 inches from stock!I’ve been through all the research and post about this waiting for mine to arrive!
I don’t know anything about the rough country is that’s a new product but yes all that’s doing is relocating your link arm therefore that one will not be adjustable I went with the Daystar pucks and the Revel links I gained about 2.5 inches!
No codes, I don’t ever lower the truck or go into the off-road 2 my truck has the off-road package so it was already an inch higher I think a lot of guys that get the codes when they raise it and lower it and play with the leveling all the time I don’t ever touch it it just self levels when I hook my trailer to it and that’s it I’ve never gotten any codes! 295 60 20 on 20 x 10 -12 offset wheels. The new ram body style is wider so if you want it to stick out just a tad in rear and the front is almost flush then you have to go with -12.
295 65 20 and 35” guys seem to rub a little. I would recommend the Revel links with the Daystar, my shop did the pucks in 20 min, very easy! Also have stock UCA’s, It’s a little bit steep of an angle but guys on here don’t seem to have issues with stocks. View attachment 62320View attachment 62321View attachment 62322View attachment 62323links because you can adjust them up and down to your liking I raised the rear and the front of mine have about 3/4 of an inch rake with the taller tires and a leveling kit I gained about 4 inches from stock!
Rebel has the same UCAs as all other trucks.I think the Rebel has the Mopar UCAs from the factory? I could be wrong. I have a Limited, not a Rebel.
I don't think you can go wrong with either option. The links can be made for relatively cheap (pic is the ones I made). And the RC is also cheap.
