ROUGH starts on cold starts?
Wolf
Come to think of it, it does it in the morning even if it ran for 10 minutes or so as I get ready for work. Would that mean it is likely transmission related?
Jamminjerry
I haven’t had it happen in over a week. I’m leaning towards a bad tank of gas TBO.
Wolf
I have 2100 miles on it. Many tanks of gas, some premium. I hope yours is only bad gas. I cringe everytime it happens because I think it is hurting the longevity of the truck with how violent it is.
Gman
Puyallup, WA
I cold started my truck in the driveway to move and re-park it. It initially stumbled as I was backing up, so I put on the brakes, then it seemed to recover and I started moving again, only to have it stall completely. Was able to restart and move the truck. Has only happened once. I never run anything in the tank but Top Tier gas.
...but it has me feeling o_O
RamCares
Michigan
Hi Gman,
We are sorry to hear that you are experiencing this. If you decide to have your dealer look into this further, we would be happy to get you connected with a case specialist to aide in this process. Please send us a private message if this is something you would be interested in.
Alex
Ram Social Care Specialist
dredge38
Mine did this for a couple of weeks before I could get it in. Would only do it in the morning after it sat for 8 to 10 hours. Actually died once. Dealership re flashed it and I haven't had any issues. Day two so far. Ill update if it happens again.
Wolf
Well, as suspected, the dealer "could not replicate" do to weather getting warmer. They did not re-flash or anything. I guess since summer is all but here, I will bring it to them in the fall if/when it starts happening again.
ksn240
This seemed to be the case for me. Make sure you use a gas station that uses high quality gas. I was using a gas station right around the corner from my house for convenience but found out it wasn't top tier gas. Changed gas stations and haven't had a problem since.
RamCares
Michigan
Hi Wolf,
We understand why this would be frustrating. When you go back in a couple months, connect with our team. We'd like to escalate a case so that a case specialist can make sure all options have been explored during service.
Jasmine
Wolf
Thank you @RamCares , I will keep you in mind and appreciate the offer.
I wasn't too frustrated because I was prepared for a "failed to replicate", because the weather was getting warmer. I knew if there was a chance it would be last week or in the fall. Looks like in the fall when temps start consistently being 30's in the morning.
RamCares
Michigan
Understandable, Wolf. We''ll keep our eyes peeled for any future updates.
Jasmine
Jamminjerry
Yep. Only use Shell. It’s been good for a while now. But I’m still gonna bring it up to the dealership when I take it in for service.
Jamminjerry
I live in Phoenix and mine was doing it. I don’t think the temperature has anything to do with this issue.
Wolf
Interesting @Jamminjerry , thank you for your input. I will definently inform my dealer if/when it happens again and try to document the weather, gear, type of acceleration, how soon into trip...
The good/bad thing is I don't have to listen or feel for it in a hypersensitive manner. Like I told the dealer, "You don't have to guess or wonder, was that what the customer was talking about? You will know it, because it is not subtle, it is quite violent."
M. Scarn
I really hate coming to these forums having to see my truck is having all the same problems. My truck is the coolest looking piece of crap out there. Very frustrating putting a lot of work into the truck to keep having all these problems. I am in the process of dealing with a drivers side floor leak issue which dealer could not replicate and now I am having stalling issues. I originally had these same exact starting conditions this thread talks about, rough start, tachometer all over the place, almost stalling, etc. This started 11 months ago when I got it. my center IPC cluster console above steering wheel also went black after about a month. I had this replaced, I think at the same time they did some sort of flash reset and the rough idling issue went away. Until now. Had my car at the dealer on June 12th for the leak issue but also told them my truck stalled a few days ago when I was starting it. Asked them to check for codes. They didn't find anything. I just thought it was a blip freak occurrence. Now it has happened the last 2 days in a row. truck sits overnight , damp conditions, truck actually starts normal no rough idling but when I put into drive it flat out stalls.
M. Scarn
My truck does the same thing, the last time it did it I thought for sure it would throw a code, it barely stayed running..I have an appointment the 8 th to drop the truck off, I have a laundry list of things for them to look at.. exhaust is clunking going over little bumps, one of the moldings on the window is coming off, my driver's seat is clicking, and the ac doesn't blow very cold. Oh and my brakes make noise if I drive for like a hour,, the truck has just over 2000 miles, my last truck had twenty thousand miles, brakes never made any noise...a brand new truck shouldn't have all these issues.. not happy with my purchase...
me either
ksn240
Make sure you are using high quality gas. I had similar issues when filling up at the pump around the corner. Started driving down the road and using a different station for gas and problem went away.
M. Scarn
Thanks, Yeah, I always do. Ever since I had the first run around. with this problem. I mean even with the worse gas this $60K truck shouldn't flat out stall like this. Been driving cars and trucks for 33 years never even thought twice which kind of crap gas I used and never had an issue. will see if tomorrow brings 3 days in a row with a stall.
ksn240
Just checking. I agree it shouldn’t happen any way, but it helped for me. Hope you get it figured out
acat
mine did start fail once, maybe I put in reverse gear to quick
