Hi All,
I’ve been looking through this thread and see that a lot of people have had similar issues to what I am experiencing.
Some back story:
2020 1500 limited
5.7 non mds
45k miles
Run 93 octane 99% of the time
All maintenance current
Issue started when it was under manufacture warranty and now under an extended warranty.
When starting my truck from cold on a hot day, with the ac set to automatic, placing the truck into reverse, slowly back out of garage, the idle fluctuates up to 2k rpm and more, down to under 500, sometimes stalling out, then surging back up and repeating the cycle. Put it in drive and slowly accelerate. The truck will sometimes surge and lurch forward as well. Sometimes the entire ac will shut down and after accelerating and getting to somewhat normal idle it will return.
The process still continues until I give it a decent amount of acceleration then it seems to normalize.
There are no check engine lights/codes to report. The techs have all been able to replicate the issue, but no resolution.
This has been going on several years for about 20k miles. It has been in the dealership countless times, currently going on a month.  The techs have had a star case open and have been in contact conducting numerous tests and parts replacements.
So far they have checked/replaced the following with no change.
Checked vacuum pressure
Checked the brake booster.
Checked spark plugs
Replaced fuel filters.
Check fuel pressure.
Replaced the PCM and updated all modules.
Replaced the MAP sensor and the accelerator pedal.
Replaced the throttle body.
Updated all software
I am sure I am probably missing something.
Another point to mention as this seems to only happen with the ac on. So logically we looked at that first. One tech thought maybe it was a surge/short in the ac compressor.
They have provided many hours of data to Star and stars position  now that they can no longer help as they are unsure what the issue is. The dealership will continue to try and find the issue but it would need to be at my expense now. I don’t fault them for that, they deserve to get paid for their services.
Does anyone have a similar experience or thoughts on what could be causing this issue?
Here’s a couple of examples
