Kmarcella4
- Sep 5, 2022
Will my uconnect 5 nav module work on previous model number screens from pre 2022 trucks?
Did you need to have the newest screen or does our module work with older screens?Getting ready to do this upgrade. I got a screen and a bezel. I have the Uconnect 5 with NAV. So, I'll be using the same module; just swapping screens. Everything looks ready to go. Only problem is I can't find a screen size setting on Alfaobd.
Does anyone know if Alfaobd is needed for a screen upgrade with the same module?
Honestly, most devices today would automatically detect a new screen and adjust settings accordingly, but I was not expecting that on this project. It can't be that easy, can it?
I don't know. I would think that, as long as the connector is the same, a screen is a screen. But, I don't even know if it has the same connector.Did you need to have the newest screen or does our module work with older screens?
No. You MUST use a 2022 part number UC5 screen for it to work with a UC5 radio module. Do not mix and match UC5 parts between Heavy Duty rams and 1500’s.Will my uconnect 5 nav module work on previous model number screens from pre 2022 trucks?
Well that ruins all my plans but saves me some serious headache, thank you for the response!No. You MUST use a 2022 part number UC5 screen for it to work with a UC5 radio module. Do not mix and match UC5 parts between Heavy Duty rams and 1500’s.
Settings are the same, 5" or 8.4".Hey Guys
So im going from the 5inch non nav to the 12.1 Nav. I read earlier in the post about changing cabin Net: ICS Integrated Center Stack to “not enabled” with Alpha OBD. But this was going from to 8.4 NAV to 12.1 NAV. I am going from 5inch Non Nav to 12.1 NAV are there any other settings in alphaobd settings that need to be changed?
Thanks in advance
Set this:So my upgrade went smoothly however my climate won’t work now. Only thing I can turn on is my “Rear” button but I can’t control temperature or fans. No other climate control tabs work except for the rear. Truck has been restarted numerous times and sat thru the night with it still not working this morning. Any advice?
Update: Hot/Cold buttons working fine nowSet this:
VehConfig 3: hvac configuration- dual zone atc
Yep, already have the uconnect 5. What I don't know is if I just buy the 12 inch center stack, would my current module for the 8.4 work with the new 12 inch screen
Did you find out what caused the issues you mentioned here?I got the unit installed but having 2 small issues...
Android auto wont display the map
The back up camera isn't working
Anyone else experiencing these issues?? Is it possible the android auto map issue is because i am using a non nav unit with the large screen?
@Jimmy07 is it possible to turn on turn by turn directions on my evic? I used to have it on my 2021 UC4 12” Big Horn. I upgraded my 2022 UC5 non nav to UC5 12”. Thanks in advanceI got done upgrading my 2022 to Uconnect 5 12inc from Uconnect 5 8.4 Non Nav. Everything works as it should but I don’t see turn bu turn navigation on my evic. I used to have it on my 2021 Uconnect 4 12inchView attachment 176490
