Got my truck back after they re-charged the system.
Left side reading 46-48 degrees
Right side reading 40-42 degrees
Weird, just weird. And that's after... Oh well, at least the temps are down (likely anyway).
My truck received the repair yesterday. It took 9 days for the parts to arrive, but once the parts arrived, the repair was completed same day. The job was decent. Only damages I noticed were a slight chip/dent on the center console in an area that is not really noticeable and a section of the driver door seal being manipulated.The currently open work order on my truck has the following statement for the A/C issue:
"Customer states A/C has poor performance. States on warm days takes too long for A/C to blow cold. Please check and advise. (TSB 24-001-20 may pertain to concern per customer)"
That's why I wonder if some of these dealers are actually doing the entire job...it almost seems like they did NOT replace the heater box assembly. I'm sure that if the ENTIRE process ordered by the TSB isn't completed you won't get the proper results.Finally got around to testing my vent temps. We have not had any warm weather since having the TSB done.. yesterday was only around 70 or so, but anyway..
49 drivers side, 44 passenger
Not very impressive.
I've worked at dealerships and it was common to ignore things when they weren't safety related if they could cut corners and still get paid.
FOLKS NEED TO START ASKING TO SEE THE PARTS THAT WERE REMOVED FOR REPLACEMENT BY THE UPDATED PARTS! If they can't show you these things it is a good bet they were never replaced at
I’m sure that happens sometimes.That's why I wonder if some of these dealers are actually doing the entire job...it almost seems like they did NOT replace the heater box assembly. I'm sure that if the ENTIRE process ordered by the TSB isn't completed you won't get the proper results.
FOLKS NEED TO START ASKING TO SEE THE PARTS THAT WERE REMOVED FOR REPLACEMENT BY THE UPDATED PARTS! If they can't show you these things it is a good bet they were never replaced at all!
Just curious, are you not allowed to keep your truck until all parts arrive? Why would they have to hold it thereWell I can tell you that the dealer is replacing the heater box on mine as they have ordered two of them, both arriving damaged. I am going on my 3rd week without my truck, waiting for parts. Apparently, another one is supposed to arrive tomorrow but we will see. My case manager contacted me and said they can't order another one until Friday due to part restriction but we will see. At this point, it's getting pretty ridiculous. @RamCares I want my truck back!
Update:Finally got around to testing my vent temps. We have not had any warm weather since having the TSB done.. yesterday was only around 70 or so, but anyway..
Nicely done. Did you DIY or purchase a kit?Performed the DIY solution Sunday morning, quick and easy. Still need to check the vent temps with a thermometer (valve open vs. closed) but it was a noticeable improvement. There aren't many glowing reviews on the TSB otherwise I would have gone that route
I got a kit from Amazon. Search "Muzzy's AC hack for Ram"Nicely done. Did you DIY or purchase a kit?
What kind of clamp are you using?I’m trying out the clamp on the heater hose. Outside temp was 72*... on max ac I had 40-41* across all vents. With reciculation off I have 40-46* depending on if the compressor is running.
With no clamp 52* left of center stack,43* right side of stack,46-48* on the ends.
I see. I’m guessing this is ok as a temporary fix or trial run. Looks like it did help your AC thoUsing the 1” clamp on the ENG out hose.![]()
Fluid Line Clamp Set, 4 Piece
Amazing deals on this 4Pc Fluid Line Clamp Set at Harbor Freight. Quality tools & low prices.www.harborfreight.com
