Odb2 sensor essentially. Dealership tools. Kind of like an inline 7 for a Cummins. Does nothing without the proper software.what is this micropod? is it like alfaobd?
i see. do the coding processes for this mod require micropod or can be done with alfaobd?Odb2 sensor essentially. Dealership tools. Kind of like an inline 7 for a Cummins. Does nothing without the proper software.
Can't do it with just aftermarket stuff you need dealership things.i see. do the coding processes for this mod require micropod or can be done with alfaobd?
No I haven't had the time yet.oh wow. tcm flash looks to be successful. I wonder if there is now a bcm config incorrect or just a missing parameter in general from your bcm software? have you compared bcm logs from your truck against a GT truck at this point?
Take it to a hardware store. Probably easier than trying to get the dealer to find you what you want. Can always use a grinder to shorten them if neededPaddles finally came in. Unfortunately I can't find any screws that fit. It's a very course thread wood screws are too course and machine screws not enough. Also needs to be a rather short screw.
I will need to take the wheel (where the threads are) into a dealerships part's department (which aren't open on weekends) and pray to God. The last time they couldn't figgure what screws it needed using a TRX or GT vin.
I can't find the proper thread is the problem. I have a grinder and should be able to shorten the screws if I can find 4 of em.Take it to a hardware store. Probably easier than trying to get the dealer to find you what you want. Can always use a grinder to shorten them if needed
