I have been having a similar problem since new. A Low drone noise. Lower RPM 1500-1800. The noise is very similar to driving a standard car and being in the wrong gear and the motor working too hard at a low rpm. Being patient hoping it would go away. Noise does not change with open or closing the windows. Does not change with different radio settings. Very annoying as it is mostly in town lower speeds.
Okay, this is different and yes, I too am experiencing THIS issue as well.
Just a quick update: I took my truck back to the dealer and, they upgraded the firmware of the infotainment system. The dealer was aware of the “booming sound” caused by the noise cancelling system so, this issue is or, should be fixed now.
Here is my “booming sound version 2.0” I just identified. This, I am almost able to reproduce on demand, and make it go away on demand as well.
Here’s how it happens:
- gotta be in higher gear, 5th-6th -7th
- gotta be coasting meaning: off throttle
- RPM between 1250 to 1500
This can be repro’d best on long downhills where, you are OFF throttle. Can’t touch the brake pedal b/c that will cause the tranny to downshift, raising the RPM above 1500
The sound comes from the back of the truck. It sounds like Robert Trujillo on the Bass, in overdrive lol! It causes this vibration in the cab, you can feel it through the door panels, the floor and, even the steering wheel.
Once you are able to produce this, you can make it go away by getting the RPM to go over 1500 (or, drop below 1250)
If you press “Tow Mode”, this will disable Cylinder Deactivation, will make the sound go away. If you shift into N while rolling, will also make the sound go away.
In my opinion, this has to do with Cylinder deactivation kicking into 4cyl mode on coast, causing some funky frequencies that will vibrate the exhaust system just right, making this booming sound.
Currently, perfecting the repro, so that I can demo it to the technicians and see if, they are able to do something about it.
