Ok... so coming back to this.
Per Airstream:
Dry weight (inluding 2-30# propane tanks and 2 batteries) is 5868lbs.
Hitch weight of 791 lbs.
GVWR on the TT is 7600
10% tongue weight would be 760lbs
15% tongue weight would be 1140lbs
So if I kept the tongue weight as close to 10% as possible I could tow the TT loaded at at its GVWR with no issues, not much of a payload, but that's how it works.
Do I have this correct or am I missing something?
To get the trailer balance (tongue weight %), we take the hitch weight (791) and divide it by the dry weight (5,868) This = .1347989093387866 (lets call it 13.48%)
Always check the math by converting back to tongue weight (5868 x .1348 = 791.0064)
So, loaded up to GVWR of the trailer (loaded evenly of course), the tongue weight = 1,024.48lbs (7,600 x .1348)
Next, we need to add in your weight distribution hitch equipment weight = 100lbs (estimated per J2807 allowance)
1,024.48+100 =
1,124.48 tongue weight at max load (GVWR of trailer)
It's important to calculate the % tongue weight first,
then add the wdh weight, as the wdh weight is a constant.
After this, you can add your other payloads to this number (1,124.48) to get your total payload on the truck with people and cargo.
Your empty trailer tongue weight would be
891 (791 dry tongue weight + 100lb weight distribution hitch)
