riccnick
Not to harp on you specifically my man (or woman), I'm just trying to keep things clear for those reading and learning. But while this statement is now more correct, it also does not mean you gain any more payload capacity. The one and only thing a WDH does specifically for your total payload capacity is: reduce it. (By the exact amount of the weight of the hitch and it's components) It does shift weight forward, but it does not reduce the weight or increase capacity at all.I should restate by saying it redistributes the weight forward with less weight on the rear axle.
Tow Setup with Air Suspension - what setting do you use when setting up a WD Hitch? Do you raise the truck all the way up to Off Road 1 or 2, or keep it at Normal, hoping to achieve that normal driving position with trailer. Could you then move it to Off Road 1 if you needed some more rise? What would that do?
Towing (and hauling) is only supposed to be done in Normal mode, where the air suspension functions as designed for loads while driving on the road.
This is FCA take on configuring the Ram for proper towing with air suspension. 1. Trailer hitch weight should not be greater than 10% of total trailer weight. 2. If you are going to use WD bars, following is recommend. A. Place truck in jack mode B. Measure height of front wheel well opening from ground to the bottom of the opening.C. Attach trailer until full load is on the truck measure again Subtract C from B, divide by three and add B to the result, difference should be no more than 1/3 of normal ride height. Adjust until within specification.Turn off jack mode, truck will auto level using the air ride system.
I do not know about using off road to tow...I would think not a good idea...but I have been wrong before
There are a few threads this is discussed. I pulled that from one of my posts there.
Lots of good discusion, here onthis subject.
I was just reading through the manual myself and it stated to place the vehicle in 'Normal' mode first, then place truck in Jack Mode.
And I agree this is a great conversation....
This is all correct and great
