logboom
- Jul 8, 2023
"Damn it Jim! I'm an average retired middle class Laramie owner, not an automobile advanced computer tech!!"
Would you happen to have a link for NR28? Or can you point me in the direction of finding a Link?
drive.google.com
It's posted above on the same Google drive. Just have to scroll downWould you happen to have a link for NR28? Or can you point me in the direction of finding a Link?
link is deadIt's posted above on the same Google drive. Just have to scroll down
Thanks for your link its working now. Installing 34.2 now.UCONNECT_12.0_UAX_NR28.1_MY19.zip
drive.google.com
Thanks again for you help the NR28 worked Im installing 34.2 now. I really appreciate it.It's posted above on the same Google drive. Just have to scroll down
Also Jimmy07 the tab for the cargo camera showed up after the update I don't know if you remember I had the truck that the soft tab wouldn't show up for the camera after turning it on with alfaobd.UCONNECT_12.0_UAX_NR28.1_MY19.zip
drive.google.com
Updated link above, and sharing againCould you please repost the files on you google drive im currently on software version 20.16 I tried to go to 34.2 but after the countdown screen radio only blinks on and off update won't start. Thanks
It says when it is updating, not to shut truck off.If you have a battery charger and access to an outlet, I'd just throw a battery charger on while doing update rather than leaving the truck idle.
Yeah, ignition just has to be in run position. Doesnt mean the engine has to ever be started.It says when it is updating, not to shut truck off.
I've only had an OTA update once. I accidentally clicked on update instead of cancel. I drove the truck while it was updating.Yeah, ignition just has to be in run position. Doesnt mean the engine has to ever be started.
We aren't talking ota updates jereI've only had an OTA update once. I accidentally clicked on update instead of cancel. I drove the truck while it was updating.Probably not a good idea.
Probably fine. The OTA package comes with a hash or checksum to verify its integrity, and if it doesn't add up to what it's supposed to be, it will be rejected. Even if you interrupt the download, it will either pick up where it left off or reject the update and try again later. Whether the update will do anything useful and/or not introduce new problems is another matter.I've only had an OTA update once. I accidentally clicked on update instead of cancel. I drove the truck while it was updating.Probably not a good idea.
The only time I've ever seen it, the engine was already running, so no shutting off.Yeah, ignition just has to be in run position. Doesnt mean the engine has to ever be started.
Is UAX PR 40.1 the latest software update for our uConnect4 12" screens?Updated link above, and sharing again
I updated from 39.7 to 40.1 and still have off-road pages. My radio was an 8.4 to 12 upgrade.Currently on 39.7 w/ off road pages from factory. Can I attempt to upgrade to 40.1? Would REALLY like Wi-Fi to work.
