BowDown
Did you have to provide an activation code?
No
thank you!
disregard it worked this morningany anyone with the 39.7 update? I can't seem to get the one I got to work. upgraded to 34 just fine. Thank you
But getting hung up at 19%.. so frustratingdisregard it worked this morning
See if this works ... UCONNECT_12_UAX_PR39.7.zipI am currently at LR34 and I downloaded the PR39.9 file, but keep getting about 19% then getting a error code 20. Do I need to go to PR39.7 1st then to PR39.9? If so the UAX PR39.7 files are no longer accessible. Does anyone else have a copy? Thanks
You could have s bad USB hub. This is a known issue with some trucksI've been trying to update my version 35 software to 37.7 and just can't get the USB to boot, the truck just won't start the update. I have formatted to FAT32, both quick format and slow, and used two drives. One is the 4GB drive that RAM calls for, the other a 16GB, neither one will boot the updater. The truck is in RUN, and I have cycled through back to RUN to try after waiting a few minutes. I get the device not supported message every 30 seconds, this is why I'm trying an update. Any ideas? This is 2020 RAM 1500 Limited. EDIT: Redid my 4GB with quick format and default allocation size checked, will try again.
That escalated quickly.I have replaced the hub, both front and rear. No luck with this USB. I have another 4Gb coming today.
