Truck will automatically drive to the set destination on Google maps. At least, I wish it did.What are the android auto enhancements?
Did you format the USBs to the correct file system (FAT32) per the TSB procedure?Using the great informations in this tread, I successfully updated my 2019 from LR-34.31 to 39.7 and then to 40.1. Took a couple of tries to find an USB that the truck liked, it ended up being an older 4 gig USB. For some reason, I could not get 39.9 to load from 34.31 but 39.7 worked and then to 40.1
It was nice to avoid paying the dealership to do these updates.
Jim
Hello, can anyone send me the update files to download through email? Cant seem to pull them from google drive.Thank you
You can't download from the link?Hello, can anyone send me the update files to download through email? Cant seem to pull them from google drive.
This one still has active links to the files.Does anyone have a link to the update files? The provided google drive link that previously had all the files now says the folder is empty. Specifically needing 39.7
Not without OP long E2ETruck will automatically drive to the set destination on Google maps. At least, I wish it did.![]()
Yeah try going to 34, then 39.9, then 40.1Ok just found this thread
My 2019 Limited recently been giving me issues with CarPlay and doesn’t like when my iPhone has a full battery and will constantly cycle connected to not connected.
My current version is 20.10. The TSB says below 20.16 not recommenced. Am I ok to update it step by step with the next version up and then up after that?
My guess is I would need to go to 20.16, and so on so so forth and do multiple updates to slowly get up to 40 correct?
Get a new radio.I have a 12uax and am at software 28. For the last week the radio will turn off every 4 - 5 mins. GPS is not even close and clock is way off as well. gps has no connectivity for location services. I tried to update to 34 with the usb it gets to 19 % then the radio turns off then on again and starts over. I can never get passed the 19%. anyone have any ideas what to do?
If you are ar KR28 you have pre-recall software. When it stops what error does it give? Each number corresponds to a different issue.I have a 12uax and am at software 28. For the last week the radio will turn off every 4 - 5 mins. GPS is not even close and clock is way off as well. gps has no connectivity for location services. I tried to update to 34 with the usb it gets to 19 % then the radio turns off then on again and starts over. I can never get passed the 19%. anyone have any ideas what to do?
