I am still dealing with my leaking panoramic sunroof. Each time I get the truck back from service, I find another scratch or interior blemish that wasn't there previously. Now, the headliner has to be replaced due to water stain marks. Overall, I can't stand my 2019 RAM, and I regret ever buying it. I think this will be my last RAM truck ever. I've been hearing that Ram Cares keeps bypassing customers to talk to dealerships, and is trying to close all their cases - EVEN THOUGH THEY HAVE NOT BEEN FIXED.
Well I got ahold of the dealer today to find out what is going on with my truck because @RamCares is really not keeping me in the loop. What they are working on still is the water leak. The say the changed out the 3rd brake light, it still leaked. New rear window and trim, still leaked. New roof seam seals or something like that, still leaks. Tomorrow they are pulling the headliner dawn again to try to see the actual leak I guess. We shall see. I also had some damage on the back of my center console from the 1st time they attempted to fix the water leak. The days just keep adding up.
Not sure if anyone with the 2020 RAM multi-function tail gate is experiencing this issue. Basically, when i use the split tail gate, I have to close it pretty freaking hard for the latch to recognize that it is closed. When I close the split tailgate with the same force as the regular tailgate, the ajar warning illuminates on the instrument cluster and it won't allow you to open the regular tailgate because it thinks the tailgate isn't closed yet.
I took it to ram and they replaced the latch and it hasn't fixed anything. And basically they dont' have a fix for it. Any body experiencing this same issue?
mine does this, I just close the split portion, then open the tailgate normally, and close it. Haven’t had an issue doing it that way
Hi @RAM8004 - If you address this any further with your dealer, please be sure to reach out via private message. We are more than happy to get you connected with a specialist for an additional layer of support while in service!
Mark
RamCares
No. They basically threw in the towel. I definitely want it resolved.
i have the same issue. haven't been back to dealer to have them look at it yet. i will have my first oil change soon and am going to have them look at it.No. They basically threw in the towel. I definitely want it resolved.
Yes, I've had this happen, and the fix I've found is to do a fairly firm close when closing any of the multi function tailgate options. Would get the warning all the time when I closed the tailgate lightly, and it would shut off ability to open with the other option until this was fixed. Haven't gotten a single warning since switching to my firm-close method.Not sure if anyone with the 2020 RAM multi-function tail gate is experiencing this issue. Basically, when i use the split tail gate, I have to close it pretty freaking hard for the latch to recognize that it is closed. When I close the split tailgate with the same force as the regular tailgate, the ajar warning illuminates on the instrument cluster and it won't allow you to open the regular tailgate because it thinks the tailgate isn't closed yet.
mine did this at first but i havent noticed it in a while. i also slam it closed now too, lolNot sure if anyone with the 2020 RAM multi-function tail gate is experiencing this issue. Basically, when i use the split tail gate, I have to close it pretty freaking hard for the latch to recognize that it is closed. When I close the split tailgate with the same force as the regular tailgate, the ajar warning illuminates on the instrument cluster and it won't allow you to open the regular tailgate because it thinks the tailgate isn't closed yet.
This seems to have gotten better for me over time, I'm closing the tailgate with less force now and still not getting the open tailgate warning. So maybe the sensor has to break it a bit, although that sounds somewhat ridiculous.A very firm close works for me to but it shouldn't be that way, especially because it is definitely latched even with a soft close. So it's definitely sensor adjustment.
