Where the hell is the deployable bed step? I can't find it anywhere. Did they forget to install it? Well I gave the dealer a call. We will see.
Pic
Was your's equiped with one? I had to ad an OEM myself. Here's some pics.Found another issue. My sticker clearly says I have the bed utility package which includes the following
- Deployable bed step.
- 4-adjustable cargo tie downs.
- Pick box lighting.
- Spray in bed liner.
Yea same thing on mine , but had the mft as well. Which from what I heard that stopped offering. Dealership ordered the side one for me for freeFound another issue. My sticker clearly says I have the bed utility package which includes the following
TPMS?This is a poll of current 2019 New Ram owners only, intended to collect data on the good and bad of this new model year truck. Doubtless there will be issues, but hopefully this poll will help us sort out the “one-off” isolated problems from the common problems that will affect us all.
Please respond by checking off each system which did not function as designed, and/or required service. If all systems are go please only select “No Problems/Happy Camper.”
- Please consider all systems.
- If a system breaks down after you take the poll, I will set it up so you can edit your responses.
- Post specifics regarding any item you selected to explain your specific malfunction.
This poll will only be as valuable as the accuracy of the responses... Good news and bad news stories, as long as they are accurate and truthful, are equally welcome. Hopefully it will help us all either be confident in our new, wonderful machines, or help us identify and resolve problems. Or both.
- YoAdrian
I had the front brake pads replaced under warranty due to the horrible screeching described thoroughly on the forum. My local dealer was great and replaced them on my first visit/complaint. The only other issue I've noticed is the random smell of coolant. Truck performs fine, and I check coolant regularly, but that random coolant smell certainly irks me.
my power sunroof and blind has stopped working.its a 2019 with 9k miles.not sure what happen or if its "Covered under warrenty".
hey i just made and appointment.its next week.i thought about the fuse.but the sliding rear window still works.Of course it’s covered under warranty, take it in! I personally would check the fuse first but even if that is blown it shouldn’t blow and needs to be looked at at the dealership.
Hydro-Blue Laramie Lvl 2, Sport, Off-Road Group, Advanced Safety Group, Bed Utility Group, Pano, 3.92, E-Torque, Air-Suspension, Power Boards
i did notice it chugged a little the morning after i put premium in at after i got done pulling my camper. went to the station and put regular in it the same day and haven't noticed it again since.Anybody have a little hiccup upon cold start when using premium unleaded? Happens to me every morning.
