ramButz
Hmm..Mine does that from time to time I wondered if it was because I needed a update or something
Purchased in June of 2019. ~22K on the odo.
The only real issues I've had with mine are with the entertainment system continuously resetting when I plug my iPod Touch into the USB. It worked okay, once, and the next time I drove it, it started this resetting BS. They ought to do better than that. In contrast, my ancient iPod Nano works just about flawlessly, through the USB, with the possible exception of the music track title randomly not advancing on the radio display.
The only other issue I've noticed is that, a few days ago, I shut off the engine and heard a scraping/squeaking noise after the engine shut off. Almost sounded like a noisy clutch fan, except that the Ram has electric fans, so who knows? Hasn't done it since then.
I suppose that the 4WD front axle harness getting chewed in half is not Ram's fault, although the "service 4WD" light coming on will give you a bit of a heart palpitation - especially if you happen to need 4WD at that exact moment. With that said, it was a relatively inexpensive fix, and only took a day to get the replacement harness, once I figured out the correct part #.
.Purchased my Ram 1500 longhorn used From dealership, have had truck a year with no issues up until a month ago. I cannot fuel the truck without 500 clicks very irritating. I do have the service number to show my local dealership, hoping they do the right thing and fix for free cause this should be a recall. And yes tried multiply pumps and pumps out of state with same results
Truck is going in next week, so we will see, needed to run the tank down to minimum fuel.
Let us know what you find out the cause was.
Finally got the truck into dealership, they are replacing the tank and filler to fix the issue. Parts on order and will drop off the truck when they arrive. Provided them with the TSA for the fuel filler issues, no help with warrenty. 907 dollars out the door and was told if it ever becomes a recall they will refund my money. I’d love to know how many trucks have had this issue just for my brain to calculate why RAM knows of the issue but won’t stand by their product. Love my truck but customer service in general is nonexistent anymore, it’s a shame..
.Finally got the truck into dealership, they are replacing the tank and filler to fix the issue. Parts on order and will drop off the truck when they arrive. Provided them with the TSA for the fuel filler issues, no help with warrenty. 907 dollars out the door and was told if it ever becomes a recall they will refund my money. I’d love to know how many trucks have had this issue just for my brain to calculate why RAM knows of the issue but won’t stand by their product. Love my truck but customer service in general is nonexistent anymore, it’s a shame.
I did not, I understand that my warranty is out, and I accept it, but there is something to say of the old school thinking of on faith, cause RAM knows it’s an issue.
Sorry to hear that Ram isn't handling it as a warranty issue for you. Keep good records (receipts, emails, calls, date & time discussed with service advisor, etc.) in case Ram does make it a recall issue and you can apply for reimbursement. By chance did you ask to talk to the area rep, see if that person will agree it was a factory defect and make good on it?
I hope that fixes it and you have no more issues.
I have this same error what did the dealer do to fix your problem?My engine light came on wednesday.it gave me a p0441 code. It comes up as evaporative emissions control system
Encorrect purge Flow. It's at the dealership now getting
