Has anyone tried 305 45 22" Tires on their stock 22" rims?
Good morning
I believe we have the same Ram, 2019 1500 Laramie 4x4; Mine came with 20’s but I bought some gloss black 22’s on eBay. Do you know if 305/45r22 will fit with no issues?
I’m looking at Bridgestone Dueler HL
Good morning
I would have to say it depends on the 22s you purchased. The info I have shared is based on a stock height Ram 1500 with the oem 22s. I believe they are +19 offset 22x9s. What rims did you get?
take a pic of the label on the side of the box, should say offset etc.
I don’t have them yet. Coming in a couple of days, 22x9
  • Like
Reactions: aai
I put on 33's on my stock 22inch wheels, toyo open country AT3s.. I couldn't find anyone that did it so hopefully this help. I also did the mopar 2inch lift kit.
How do the Toyo Open Country AT3's do in the rain?
How's the road noise at highway speed?
Add my name to the list - had a set of General Grabber UHP 305/45R22 put onto the stock 22" wheels this morning. Loving the ride quality already, they sure seem, "grabby" though. Guess that's how they earned their name :ROFLMAO:
I'd been considering those but General's specifications show the "approved rim width" range of 9.5 to 11.5 inches.
The OE rim width is 9". I know a half inch isn't a lot but...
Are the 305/45 22s hurting fuel mileage? I drive a lot and don't want to totally kill my fuel economy. They seem to be just a little taller than factory.
they hurt mine a little but I went from the 275s 20s. Maybe 1.5 mpg
It probably isn't that bad because your speedometer is off and you are actually traveling farther than your odometer indicates. I don't check mileage / economy but I think it's significant.
I got the scanner that allows for speed odometer adjustments so it’s accurate.
I can avg 18 mpg hwy and local jamming around NY. i have nitto G2 terra 305/45/22
My laramie running sport OEM 22s with Nitto terra grapplers G2 size305/45/22 ... the slightest rub on the right pass front wheel liner at full lock. nothing to worry about rides great and looks awesome!
Level or lift, or purely stock?
Darn. Just realized you had terra grapplers and not ridge grapplers.
These look great! Any issues with rubbing? I have a new 2021 Laramie with 22's and the OEM Goodyears look pretty weak.
