Jordan2929
I also noticed rubber strands coming off my sway bar bushings, not too worried about that but will keep an eye on it.There isn't another bracket on these trucks that is bent and has a crack, I checked as many as I could see on y truck. Someone else already posted their bracket isn't cracked. You are right though, could be nothing. My dealer was taking one of their new trucks onto the hoist to look at the cracks.
What I can say is that the left side sway bar bushing is wearing slightly, everyday there are more strands of rubber and plastic peeling off. The plastic insert has moved away about 3/16" from the rubber bushing compared to the right side that has not moved and is not shedding material, also may not be part of the clunk, but at this point there aren't many suggestions other than loosening and tightening everything which isn't exactly a fix. It also appears there aren't many people actively trying to DIY diagnose to get something happening a bit sooner.
I know ford uses some type of white lithium grease on there sway bar bushings because it gets everywhere when I have to remove them.
