Front end clunk while turning - FIXED - TSB # 23-047-18
Jordan2929
Syracuse NY
There isn't another bracket on these trucks that is bent and has a crack, I checked as many as I could see on y truck. Someone else already posted their bracket isn't cracked. You are right though, could be nothing. My dealer was taking one of their new trucks onto the hoist to look at the cracks.
What I can say is that the left side sway bar bushing is wearing slightly, everyday there are more strands of rubber and plastic peeling off. The plastic insert has moved away about 3/16" from the rubber bushing compared to the right side that has not moved and is not shedding material, also may not be part of the clunk, but at this point there aren't many suggestions other than loosening and tightening everything which isn't exactly a fix. It also appears there aren't many people actively trying to DIY diagnose to get something happening a bit sooner.
I also noticed rubber strands coming off my sway bar bushings, not too worried about that but will keep an eye on it.
I know ford uses some type of white lithium grease on there sway bar bushings because it gets everywhere when I have to remove them.
immersivenc
Don't want to start any witch hunts as what I'm about to say is hearsay at this point. Take what I'm saying with a grain of salt, but:
We have received some intel that FCA is aware of this and is currently working on a fix. They are freezing all cases opened with those having the clunking. From what I understand, they are investigating a potential issue with the lower ball joints. I'm told they were a new design and it's possible that they need to be reengineered, or a bad batch of them made their way to the assembly line. I'm hopeful that if they can confirm this is the problem, a TSB will soon follow. You guys will know as soon as I know anything further.
YoAdrian
Moderator
RI, USA.
If your intel is right I would consider that good news, as it means they are taking the problem as seriously as they should, and are dedicated to applying a real fix for it. Here’s hoping. That gets two cartoon thumbs way up. (y)(y)
Jared B
Site admin
Vancouver B.C
Definitely good news and it wouldn't surprise me at all. Hopefully they've got a resolution out soon. (y) Thanks for the update.
warvet
Here is what I see. My left side linkage is facing towards front of the truck more. Right side is facing towards left side of truck more. And the rubber boot around them is sitting differently. Left side also has more rubber shredding. These pics aren’t perfect but my eyes are good enough to Know they aren’t matching. E82C21E3-88B9-4456-8A8B-E1AC5EBC7FCE.jpeg 71BB17BE-2FE4-464A-B7B7-8B15D85C9E02.jpeg 9E7EF762-54FE-47BE-9CDE-E795606A78C4.jpeg B1E94889-4A26-4F73-8325-1AADC3A48DBA.jpeg 1067D1F6-72D2-46FB-A3C7-2A4A053525AA.jpeg 03A0B48F-3DF9-4C6A-9114-6317F5877A68.jpeg FB25996E-3B82-430B-9955-2D162B5EC9B6.jpeg BE8FF891-997E-4A50-B028-A9C8EA697D07.jpeg 3D9B1C1C-4D02-4349-9F0B-3D7B228C9539.jpeg 0254BC44-89B5-4124-A438-1F23684878C7.jpeg
Douglas31
How about a poll of build date clunk no clunk?
I was thinking the same thing. Mine was built July 18th and has clunk. I have an appt with dealer tomorrow and I am curious to see what they say.
warvet
June 21 with a slight clunk maybe once a day now
immersivenc
Keep us posted on your dealer’s troubleshooting process.
Delmonico_19
Alright guys I have a 2019 ram 1500 Laramie. Clunking noise has progressively gotten worse. I’m also a mopar tech at the dealer. I have been looking for the sound on my truck and I’m thinking it’s from the sway bar. There is a tech tip (on the parts side) that states they want the sway bars returned for inspection. Sway bar is on order which is on a small back order. Ordered sway bar links and bushings too. When parts arrive will keep you guys posted. Will try keeping you all posted as soon as i see a bulletin or any star release about this. I’m a tech and I feel the pain of driving with the noise and trying to find it. Try being patient
immersivenc
It’s great to see you here. We too suspect some combination of sway bar/links or ball joints. Thanks for keeping us posted, there are more and more of us experiencing the issue.
Douglas31
I’m so angry after my service appt I can’t even post about right now. I wouldn’t have anything appropriate to type.
warvet
My service manager has the issue too. I just left the shop. He swears it’s the ball joints. I told him my $100 is on the sway bar. We crawled under his to take a peek.
immersivenc
“Could not replicate?” I’m basically done with my service dept until we have a FCA provided fix or if @warvet ’s dealership figures it out first I’ll be driving over an hour to their service dept. Then we will all celebrate our clunk free trucks over a beer. I can envision it now...
Delmonico_19
It’s all in articulation of the suspension when it pops. I personally feel that just turning or any bumps would possibly be a ball joint. But mine seems to only pop under articulation like going into my driveway etc.
