theblet
- Feb 8, 2021
Or bothNope. I get 16-16.5 in the city.
If you are getting 18 city, it's not because of 3.21 gears, it's your eTorque.
Yea, so does a 1977 VW Rabbit but the homeless guy pushing a shopping cart will pass it.Yet I get 18 in the city, you?
Gotta glide when they run out of gas.Except the simple resistance of air has a 3.21 struggling to get that fast. 3.92 trucks just glide along.
Or both
The engine's internal friction and pumping losses probably come out in the wash if you assume the transmission will compensate and keep you in the "right" gear.Nah. I'm sticking with eTorque, unless you can explain how a truck with 3.21 gears is more efficient in the city.
Because rpm’s are lower in every gear with 3.21s. you probably won’t see much of a difference in bumper to bumper traffic tho.Nah. I'm sticking with eTorque, unless you can explain how a truck with 3.21 gears is more efficient in the city.
1st and 8th should be different.
Easy, lower rpm's. Less rpm's, less fuel burn.
ETA
That seems to disagree with your same rpm premise and I just looked at 3rd gear, look at the other 6. 3.21 truck is 1-3 mph in every gear, if you worked backward and matched the speed, the 3.21 truck is turning less rpm in every gear to achieve the same speed
At a steady speed of 35 MPH, the 3.92 truck will be in 7th gear at 1213 RPM's. The 3.21 truck will be in 6th gear at 1183 RPM's. 30 RPM's is not going to make any difference. In city driving, both trucks will spend most of the time accelerating, decelerating, and sitting at traffic lights. In that situation as well as steady speeds of 35 MPH, 3.21's have zero advantage. Even if the speed was bumped up to 45 MPH, a 3.21 truck could not hold 8th gear under a load. The truck would have to shift down to 7th gear at 1278 RPM's, while the 3.92 truck is in 8th at 1245 RPM's.
I don't like eTorque, but I never said a word about it not having an advantage in city driving. In heavy stop and go traffic, it could easily get 2 MPG better economy than the standard Hemi.
someone will just start another thread!Man, I can’t wait to hit 2000 posts!
Missing the point, or distracting from it, that it *won't* be in the same gear at the same speed. The 3.21 truck will often be in a lower gear than the 3.92, until you top out at 8th.That seems to disagree with your same rpm premise and I just looked at 3rd gear, look at the other 6. 3.21 truck is 1-3 mph in every gear, if you worked backward and matched the speed, the 3.21 truck is turning less rpm in every gear to achieve the same speed
