OK, well Tuesday and I did research, and found that earlier built RAMS (New DT MY 19) have HVAC Module control issues ref cooling, and there is a TSB put out ref the earlier built vehicles. Getting to 100-110 here (And yes, friggin hot in the middle of TX between heat index's and humidity), and AC was doing OK, but running around town, not so much, better when air moving over condenser. Yesterday, went to Dealership (I called on Tuesday and talked to another SA, mine was on vacation, and got info on TSB out). SO had TSB HVAC module reflashed and AC working better, even had to turn down a lil and redirect vents. Seems like TSB changed how AUTO works on ATC Dual systems and had fan pushing more Air. Now I do not go around putting a meat thermometer in my vents, so on that aspect cannot speculate. Will also attach TSB for PPL. Now my Truck is an April 2018 Build that I bought 1 Aug 2018. I have also had all the recalls done for this particular truck and build date. Good Luck to all ref AC issue.
MY only question, has ne one seen any TSB's on single HVAC controlled systems? Posting TSB below.
