Just a comment on folks regarding vent air temps. The equation for cooling is:
CFM x 1.08 x air temp diff (inside cabin - air vent temp) = BTUs of cooling
airflow & airflow temp is directly related to capacity / output.
For the same cooling requirement, you can use more air that is warmer, or less air that is colder, and have the same results. Typically in commercial HVAC systems the air temp is 55F (for 75F space temp). The 55F also dehumidifies.
For a vehicle I assume they size things a bit different to try to cool a hot space down quicker, since the system is on/off more often.
We don’t have the info on truck cabin airflow, but if the fan in the truck moves more air than say your other vehicle, then it might not be “wrong” that the vent air is warmer in the truck.
We also don’t know if the engineers calc’d the cooling requirements correctly to determine the truck airflow and airflow temp requirements. So who really knows.
We know that some people in this thread are dissatisfied with the effectiveness of the air conditioning system. We know that others are pleased with it. Some are convinced the Ram system is operating insufficiently based on the contention that the Ram is universally “ten degrees” warmer than other truck manufacturers at center vent by design. We know what the Ram spec. is since it’s been published here. Despite the claim, we still have not been advised what the specs are for other makers.
I watched the TFL video, which I suspect was to prove that all rams are 10 degrees warmer at the vent. Interestingly, even though there was a 10-degree difference at the vent, the interior measuring point temperature of the Ram ended within 1.7 degrees the F-150 in the same allotted time.
Since some Ram owners are satisfied with the AC system, and others are not, some continue to assume that individuals who are pleased are just biologically more easily satisfied by warmer temperatures. Of course, from a human perspective, that works both ways. Either way, it is not a verification of vent temperature or the overall performance of the system.
What is being ignored in large part is the possibility that there is an inconsistency in delivery performance as the vehicle leaves the factory. We know there is one contributor in this thread that complained to the dealer about AC performance and it was resolved. I actually tested mine and found it beat the factory spec. by one degree at 44 degrees. If there were always a 10-degree difference from “other trucks” as a result of a design issue, there shouldn’t be any Ram that meets the Ram factory spec at all!
With respect to the TFL video, I think these guys generally do a fair comparison test. But I would submit that ordinary cooking thermometers may lack the accuracy and consistency in read-out from unit-to-unit for true comparison (I used a borrowed digital thermometer when I took my readings). However, that aside, there was never a baseline verified for either truck against the factory spec. which is a testing norm (even though both trucks were “new,” the Ram’s motor looked like it had seen quite a few miles). Just because both trucks are “new” does not mean they were delivered meeting factory specifications. We always see examples of this.
2019 Ram (DT) AC Performance Specifications:
- A/C PERFORMANCE TEMPERATURE AND PRESSURE
Ambient Air Temperature (Apparent) | 21°C
(70°F) | 27°C
(80°F) | 32°C
(90°F) | 38°C
(100°F) | 43°C
(110°F) |
Air Temperature at Center Panel Outlet | 7°C
(45°F) | 7°C
(45°F) | 13°C
(55°F) | 13°C
(55°F) | 18°C
(64°F) |
Compressor Inlet Pressure at Service Port (low Side) | 138 to 207 kPa
(20 to 30 psi) | 172 to 241 kPa
(25 to 35 psi) | 207 to 276 kPa
(30 to 40 psi) | 241 to 310 kPa
(35 to 45 psi) | 276 to 345 kPa
(40 to 50 psi) |
Compressor Discharge Pressure at Service Port (High Side) | 1034 to 1724 kPa
(150 to 250 psi) | 1379 to 2068 kPa
(200 to 300 psi) | 1724 to 2413 kPa
(250 to 350 psi) | 1999 to 2689 kPa
(290 to 390 psi) | 2413 to 2965 kPa
(350 to 430 psi) |
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 17 July 2018. Now at: 035449 miles.
