Hi guys I am new at this I have the same situation I bought a module from 2500 It came with the screen and update cable my question is do I have to still repin
Nope, the repin adapter is included in your picture.
Thanks for the info
Now i need how to change it in the bcm can you point me in the right direction .
From my reading you are the men to speak with again I'm new at this .
Thanks for the info
Cab Net ICS integrated center stack = Disabled.
Cabin Net DCSD display screen module = Enabled.
Also, look at post 309 in this thread.
If anyone knows where to find a set up, or parts at a reasonable price please let me know. Over 2000 for bezel module and stack alone here in louisiana..
Thanks everyone,
John
Hello everyone, just swapped from 8.4 to 12.1 but the connector that goes to back of screen is diff. The one that was repinned. Is there anything that can be done?
Question:
I did the swap out this past weekend from the 8.4 to the 12.1 inch screen. Thanks to this page and @Jimmy07 it worked flawlessly (it took like 20 mins). I had zero issues. But . . . in my angst and excitement to install the new system . . . I failed to erase any personal data on the old 8.4 inch UAV brain I removed. Should I be concerned? Is there a way to erase it? I do plan on selling it to recoup some of the $1,900 I spent on the upgrade. . . .
Please advise if this has been asked . I have 2019 1500 (new body) with 8” non nav system. Level 2 alpine system. Looking to purchase 12” and upgrade . I’ve seen several n eBay approx pricing 6-700 up to 12-1600. Part I’m unsure about is are some of these screen sold without the model/brain which is needed or are they usually sold with what’s needed ( electronically ) ?
2nd can someone provide short list of items I’d need for the upgrade . So far I’m aware of alfaobd only for programming . I really appreciate any help given .
I just did it last week and I have same setup as you.
You need:
Screen (and bezel)
Media Module
LVDS Cable
Jumper Cable Connects from Back of 12" screen, is either black or grey and connects to your existing 8.4 small harness
ALfa to program
Security code for media module if it's not new
Thats "it"
Anyone know the correct part number for the 12" Bighorn Bezel? Seeing different part numbers for bezels and of course all mopar sites just show the diagram and not the actual bezel. Looking for that bighorn marble finish at the top of the bezel
The information in the link below has most of the information people should need to do the swap. I think the info should be stickied on the first post.
Posted by @theRamguy and information by @Jimmy07
Not sure if any of the documents have the part numbers of the 8 pin connectors and terminals for the repin harness but I added them below from a previous post for the people that would like to build them themselves.
Female connector- https://www.digikey.com/products/en?keywords=307001081
Female connector terminals (5)- https://www.digikey.com/product-det...amp-connectors/1393366-1/A101883CT-ND/2700940
Male connector- https://www.digikey.com/products/en?keywords=309681081
Male connector terminals (5)- https://www.digikey.com/product-det...tors/2-1419158-5/17-2-1419158-5CT-ND/11492481
This has most of the information you need. Should this be sticky?
I can send what you need.
Send me a pm
Hey, it’s a long shot but does anyone have the 39.9 update for Ucx module (Canada)
I just finished installing the 12” screen, I want to say a big thank you to everyone who helped here and shared their experience! Most of the answers are easy to find through the search;) But now I'm going to update the software, can someone tell me what software is better to put on my 2019 bighorn, the latest 39.9 or is there a more stable one?
I just finished installing the 12” screen, I want to say a big thank you to everyone who helped here and shared their experience! Most of the answers are easy to find through the search;) But now I'm going to update the firmware, can someone tell me the update manual via usb? And what firmware is better to put on my 2019 bighorn, the latest or is there a more stable one?
Post 2091 google drive, has step by step if yours is uax 39.9 is the newest
Going to be installing the radio today. Where does this black bracket go?
You need:
Screen (and bezel)
Media Module
LVDS Cable
ALfa to program
Thats "it"
Thanks for posting that as I am sure it will help. Can you tell us where the best place is to get these parts? Do you remember part numbers by chance?
Thanks in advance.
