Joseram2019
 - Apr 21, 2022
I do think the issue is with the module. It isn't that it's a different part number because 2388 and 7978 part numbers are virtually identical hardware wise. I don't know why only the left speaker would not work though unless it's a wiring or hardware failure.
Thank you theRamguy, So... I just went and borrowed a buddy of mine's Module, but his truck is Canadian. His module number is 68329882AJ, which I found out will work just fine. We plugged in and right away I had sound to all of the speakers (tested each one individually). but then had no backup camera or passenger heated seat icon on the screen. After 3 or so hours I went out there to take it off and noticed that I now had a backup camera and the passenger heated seat icon showed on the controls display.........but had no sound at all to any of the speakers, I tried to do the soft reset by pressing down the volume knob and it wouldn't reset. I saw somewhere on here that it may take up to 48 hours for the module to fully function correctly. do you think this is the case? should I try it again? my buddy is out of town for a few days and told me I can use it if needed.
