Hawkshot99
- Jul 7, 2022
I have them back from powder coat. If you place an order soon, make sure you specify in the notes you want that version. We still have some of the previous gen brackets packaged and ready to ship so if it isn't specified, you could get the older ones until those are gone.@Shifts And Grins Fab - just checking back in with you to see if we’re any closer to being able to purchase the newest version brackets with extra holes for the other trims yet?
Perfect. Due to the holiday, they will ship out on Monday. They will be boxed today and you will get a shipping notice with tracking number. Thank you for the order and support.Nice! I just ordered mine with a note requesting the newest version.
Just wondering if you have a picture of the final product of version 4 of the brackets, so I know how I can mimic it on my 3rd generation brackets![]()
Not a bad plan. It is pretty tight in there.Looks like the modified ones I did for my ram on an earlier version. Look great and they work just as well. Dual row curved 30 is butter. I did go through the bumper grill opening when the grill was out to set her in there then bolted the grille in then the bar from underneth/backside.
The bumper is super easy to remove. I only remove the bumper for the TRX install though. The 5th Gen 1500 install is pretty quick and easy with the bumper on.Has anyone removed the bumper completely to install the brackets/light? Seems pretty minimal work to remove - two plastic trim pieces and 6 bolts. I’m considering it so I can set the bumper on a table instead of struggling on my back under the truck.
Very nice!I did some pre-work today for my upcoming install. I’m still waiting on my replacement grill to show up to do the actual install, but I took some time to get the switch installed. I’m using the Rough Country light bar, and I was less than impressed with their switch so I bought a cheap o Amazon round button to use instead. Pretty happy with the location I picked.
Looks great. We now have the new style with added slot up top. You all spoke and we listened. If you need the new style please specify in your order notes as we have some of the inventory left from the last run. We are trying to make sure those get shipped to Rebel and TRX owners and the new style to everyone else. We are looking at other lighting options for the front. If you've seen my TRX you know I want all the lights. lolToday had time to fit that extra hole in the bracket to fit the led light higher. We drilled on the bracket as high as possible. Which makes it 1,5 cm higher. Which is 0,59 inch for you guys
and the result is perfect, it is in the middle of the grille opening now, as you can see it is centered behind the parking sensor
Also adjusted the high beams, that the led bar goes on when the high beams are on, by soldering an extra cable on the green/white cable that's inserted in the headlight unit.
It was a bit of panic after testing that only the high beam on the right headlight and the led bar went on, but after a few cycles of vehicle starts, the issue reset it self. Probably cause the plug was out of the headlight unit, although no error codes or notifications were given in the car that there is something wrong with the headlights.
So I see a bit of improvement, now that the LED bar is placed more centered, but still I am surprised about the fact that the LED bar isn't brighter, especially if you see the amount of lumens it throws out.
Specs from the website:
So a pity I didn't went for the double row led bar although the difference in lumen/watts isn't much.
- 12000 lumens
- 150 watts
- Contains 30, 5 watt High Intensity CREE LEDs
- 30 degree spot beam
Maybe wiring the fog lights to go on with the high beams could be an option.
- 14400 lumens
- 180 watts
- Contains 60, 3 watt High Intensity CREE LEDs
- 8 degree spot / 90 degree flood combo pattern
I am not a fan of A pillar lights on a Limited trim, so I am wondering if there are other, discreet places, to put small aux lights. Someone tried on the tow hooks? I know they exist for the rear tow hooks, but didn't see them for the fronts.
do you have a front picture of the dual row centered in the lower grill?Did my install today. I decided to take the bumper off completely to install. I have active air dam and needed to swap the grill as well I’m glad I removed the bumper as it was pretty tight in there even with it on the bench - it would have sucked doing all that work under the truck. I used a RC 30” dual row, and it fit perfectly in my Laramie in the upper hole of the new version bracket. 3 hours total taking my time and waiting for my wife to help me put the bumper back on.
