kittyjo
about ready to pull the trigger on 3.5 rc lift and 35 inch nitto terra grapplers g2 on stock 20inch rims... anyone have this setup ? any suggestions to consider when installing..
19llhpb
North Central Indiana
Sounds like a nice setup. I have the 3 1/2” RC with 35x12.5’s and ‘0’ offset Mayhem wheels and had to trim some plastic. You should be good going with the stock wheel offset and not have to trim.
Joeyp
Jersey Shore
3.21. Do notice a slight difference. But not a big deal
I see a lot of dudes are having an issue with 7th and 8th gear on the highway...My truck just shipped today. I need to figure out what Im gonna do ASAP
kittyjo
thats the plan just keep it clean and simple but yet effective for my use.
nicodywill
FWIW I have 285/65R20 (34.6x11.2x20) Nitto RG's on my '19 Ram with 3.21 gears and it felt a little different right after install so I purchased the Rough Country Speedo Calibration tool (it adjusts tranny shift points based on tire size) and made mine feel the same as prior to the new tire install.
I was looking at those tires myself and heard from a lot of folks that those Terra Grapplers are LOUD. If road noise is any worry you might want to consider another model. I went with the Ridge Grapplers on the stock wheels (for now) over the G2's and K02's based solely on the road noise differences.
Joeyp
Jersey Shore
I didn't know they made one thanks....I think the Diablo Pulsar does the same thing plus a little boost in throttle response might be good. I wish I put in the 3.92!
kittyjo
How’s the ride?I listen to music loud so I don’t think noise should be a problem. LOL
Joeyp
Jersey Shore
The Terras are louder than the Ridge?
nicodywill
Keep in mind the Diablo Pulsar is a piggy back PCM unit that must be removed if you take your pickup into the dealer, otherwise it can and will impact your warranty. The dealer specifically told me that the Rough Country unit was good to go and does not affect my factory warranty. it's also ~$500 bucks as oppose to ~$180 for the RC unit (essentially a $320 upcharge for a pedal commander).
It's stiffer but is also more stable if that makes sense.
Yes, that is correct from what i've read and been told.
Joeyp
Jersey Shore
I thought it was the other way around...
nicodywill
That's not what I found when I looked and asked around. I figured the G2's would've been more mild on the pavement but read and heard a LOT of feedback about the noise they emit.
I have Ridge Grapplers myself and have been very satisfied. They do produce noticeably more noise than the stock highway tires however they aren't what I would call loud.
With the radio on at a normal volume (lvl 10-15) all tire noise is drowned out entirely.
I was initially worried about killing the MPG's with the lift and tire swap but after a bit of a break in period and a few tanks of fuel through it I can say I haven't lost hardly anything in terms of MPG.
Joeyp
Jersey Shore
Good to know and yes I agree on the Pulsar. I have a Diablo tuner for my 14 Bighorn and there was more flexibility to play around with the settings than now. It looks like ill be doing the pedal commander and the RC like you. I just wish the pedal commander didn't have that black box they want you to mount but i can stuff it underneath somewhere and use the bluetooth to change when necessary.
Why didn't you just run a 35/11.50 tire? I'm leaning toward the 12.5 so that extra inch will probably hurt the MPG for me...
nicodywill
I went with the tire size as it's what was recommended the lift manufacturer as their largest size.
The 285/65 has about 1/2"~3/4" of clearance on the back side from the upper control arms. Any wider of a tire and it'd be too close for comfort.
Additionally, I get (almost) all the of added height, stance, looks and clearance and gave up nearly nothing in terms of MPG's so it ended up being a win-win.
Joeyp
Jersey Shore
Rough Country? Do you have any pics of your truck?
kittyjo
Wut is the difference between 35 11.50 20 and 35 12.50 20? How much wud stick out?
Joeyp
Jersey Shore
I am mostly done with it for a couple months so I’ll post up.
5.7 Laramie Crew Cab 4x4 w/ 3.21 Gears
3.5 Inch Ready Lift
35x12.5R20 Nitto Ridge Grapplers
20x9 +1 Fuel Vapors
Added:
Flowmaster FlowFX Direct Fit
Pedal Commander PC07
Cheap Black Nerf Bars (Till the OEM Power Steps come in - Feb 19th
OEM Bed Lights
BakFlip MX4
On Back Order:
OEM Power Steps
OEM Bed Step
OEM Trailer Brake Controller
Edit: Before
Truck looks great...Any rubbing or trimming with the +1? I was gonna rock the +14 to be safe.
  • Top
