MValdez
North Wales, Pa
**on the nitto website - Ridge Grappler 305/55R20 116Q *stock Number #217860
I havent noticed any significant changes in MPG as i keep the center gauge option on fuel economy too. The Biggest change i noticed right away is a drop in Truck's acceleration due to the extra weight and wider contact patch from the nitto tires w/ dropstar wheels vs the ram's stock 22s and tires.
*Ram's Stock eagle touring Tire 285/45/R22 + 22" wheel = 77lbs x 4 = 308 lbs (11.2" wide Tire)
*30555R20 Nittos + 20" DropStars MB645 wheel = 91lbs x4 =364 lbs (12.44" wide Tire)
I forgot to add I keep psi @ 40 on nittos
Jetisondm
ORP w/ 2” Level, still have 1” rake
Savagescott
Dmalonecentral
I am mostly done with it for a couple months so I’ll post up.
5.7 Laramie Crew Cab 4x4 w/ 3.21 Gears
3.5 Inch Ready Lift
35x12.5R20 Nitto Ridge Grapplers
20x9 +1 Fuel Vapors
Added:
Flowmaster FlowFX Direct Fit
Pedal Commander PC07
Cheap Black Nerf Bars (Till the OEM Power Steps come in - Feb 19th
OEM Bed Lights
BakFlip MX4
On Back Order:
OEM Power Steps
OEM Bed Step
OEM Trailer Brake Controller
Edit: Before
Mikey1641
Wow. Great setup. This is exactly what I’m looking for.
ghostface
3.5 Inch Ready Lift
20x9 +1 Fuel Vapors
Added:
OEM Bed Lights
BakFlip MX4
On Back Order:
OEM Power Steps
OEM Bed Step
Edit: Before
Looks fantastic. What gearing do you have?
ghostface
3.21
Do you have any problems with sluggishness or anything wrong with 35s and the 3.21 gearing? I have heard some people having problems just in terms of going downhill or just general sluggish performance (as apposed to stock tires)
Dmalonecentral
I have read that too and it seems to me it’s all hyperbole. The difference is negligible and not enough for me to even worry about it. It still has plenty of get up and go. I had a 16 with the 3.92 and to be honest I didn’t notice much of a difference going down to the 3.21 either. Let’s face it, we drive trucks for a reason, if someone is worried about shaving tenths of a second off of their quarter mile they probably should get a Hellcat.
rbram
3.5 Inch Ready Lift
20x9 +1 Fuel Vapors
Added:
OEM Bed Lights
BakFlip MX4
On Back Order:
OEM Power Steps
OEM Bed Step
looks great! Did you put the oem led bed lights in yourself? Did the dealer have to flash or is it simply plug the pins into a factory plug?
Dmalonecentral
I was going to order them online and install myself till I saw the installation instructions and that you needed a flash for them to work properly. I went ahead and bit the bullet and just paid the dealer to install them since they were doing the lift and tires anyway. I paid like $310 total ( lights and install ). I think it was worth it. I think there were like 70 steps in the instructions and the Mopar installation time was like two hours. I initially thought I would just be able to pop them in.
rbram
Thanks for the response. I think I will do the same. I too initially thought it would be as simple as popping them in and there would be some existing harness to put the pins into. Thanks again.
PorBoy
Millville NJ
^^^. Oh wow, that is nicely done and quite an upgrade not to have to lose your oem wheels over..
ghostface
2019 1500 4x4
2" Procomp Level
Nitto Ridge Grappler 285/65R20
Huper Optik IR Rejecting film 5%/20%
stock tires w/ level
tire comparison
285/65R20 on factory rims
Nice! Do you have any rubbing by chance?
