Ultimate OBD JScan Thread
So when you say, step away from the vehicle after shutting it down for 15-20 minutes. Do I leave the cables and OBD2 reader plugged in or do I re attach the cables to their original plugs and walk away? Sorry even writing that seems like a question I should be able to find an answer to.
Just make sure everything is closed up and the key is far enough away from the truck so that the computers can fully go to sleep
Thank you all for your info on this!!! I have successfully done the DRL’s, adjusted for tire height, fog light with high beams and the rear turn signal alternating with brakes. Anything else you guys suggest? So much fun!!!
2021 Ram 1500 Bighorn
Ive done these and lowered my TPMS pressure threshold.
You can also program some extra keys if you want to.
Everything else that I know of requires changing out or adding hardware
what is "the rear turn signal alternating with brakes." any video of this in action?
It means the brake lights come back when the turn signal turns off. Default is the brake light disappears on the side you have the turn signal activated. I made a video in this post.
Post in thread 'Ultimate OBD JScan Thread'
what post# shows u how to make this change> i dont feel like looking through 16 pages lol
Does anyone know if you can add other trim level themes for the cluster display and radio display? When I first looked at my truck at the dealer (used 2022 rams sport gt) it had what looked like a Longhorn display, pic below. Took delivery and it's no longer an option. Got it from a Ram dealership, and km's don't look off from previous service history and carfax, trailer trip is way lower than oxo, so I don't think it's a different cluster. It had a recall done and I believed it needed a reflash so that may have wiped out previous owner coding changes. Any idea if the trim level can be changed with JScan? Thanks
Yes, you can change the splash screens with Jscan. But the theme is under radio display settings
Thanks for replying, much appreciated. Any idea where in JScan this is done? I've been pouring thru it and I can't seem to find it. On my JL Rubicon it was pretty clear but this one not so much. Unless I'm blind or dumb which is entirely possible 😂
The splash screen is just what shows up when you start the truck. I have mine set to say SPORT. But I also used the TazerDT to set it, but I have changed it with alfaObd before as well.
I think this might be it……
Do you have to enable the themes in jscan as well?
