Ultimate OBD JScan Thread
What is this material for the steering wheel?
Any help would be greatly appreciated I have JScan and my tires are 275/70/18 when I go into the tire change section the options I see is 33 or 33.25 I think it was if anybody could clarify this thanks in advance
Pick one and see how close it is to GPS speed. It's closer to a 33 than 33.25.
I'm not experienced with Jscan, but alfaObd has he option to choose a p-metric tire size to match what you are using, or you can enter it by revolutions per mile to really fine tune.
You can measure the tire manually to get a close measurement in inches. Then fine tune it with a speedometer app. Just don’t plug it in to the truck while you’re doing it
Been going through and doing some of these mods. I tried using alfaobd on windows but it wasn't very user friendly. then turns out I should have just done jscan (apple stuff). I was able to adjust the temp at which heated seats come on in alfa which is nice.
I have what is probably an easy question for you guys (I assume i'm lacking the right mirror harness or something).
I activated tilt mirrors in reverse (driver, passenger, CSM). It added to my 12" menu but when I try to turn it on in settings, I get an error. Thoughts?
Idk. Maybe @Jimmy07 can help
Did you swap in memory capable mirrors?
I recently changed tire size on my 2021 ram 1500 and after maybe a week key fob only works to lock and unlock doors if I’m really close to truck anybody else experience this
I just remembered I also did the tailgate ajar indicator both with JScan I’m wondering if it might have anything to do with my issue
Can’t say that I have. Tried changing batteries or your other fob?
  • Back
