rickey55
- Jan 6, 2023
This.It's the Mopar Cat Back which is made by Borla(S-Type). You can order it from you local dealer or online.
false the gt exhaust is not the same as the mopar cat back, it dosent even look close to it and also has rear resonators...This.
Yup. I find myself posting the pic of my GT exhaust on the delivery skid often. Looks EXACTLY like the stock exhaust. Only way to tell is by looking at the numbers.Man if I had a dollar for every time someone who obviously never saw the GT exhaust said it was either the Mopar catback or Borla S type.
Yeah, the shop that installed mine didn’t want to do it because they look exactly the same. Had to point out the part numbers and told them just wait until you hear it.Yup. I find myself posting the pic of my GT exhaust on the delivery skid often. Looks EXACTLY like the stock exhaust. Only way to tell is by looking at the numbers.
Finally got the GT exhaust installed today on my 22 Limited. Its has the perfect sound for me, quiet in the cabin when cruising and aggressive when you get on. I attempted to install myself in the garage with air suspension set at its highest and rear tires on ramps, removed the spare tire and heat shield and its was a complete failure, I simply did not have enough clearance to maneuver the exhaust out. I put it all back together and took it to a shop and was installed in 26 minutes. Thanks to everyone on this thread whom previously installed this exhaust and posted here about it, it really helped me make the right decision. Now looking for a deal on 5" tips.
If anyone is interested in buying an 22 OEM dual exhaust with only 800 miles it and can pick up in Ohio, hit me up and make me an offer.
I have this same set-up on my 2022 Ram Laramie NON G/T Sport 5.7 (non-E-torque) - built on May 30, 2022.You and I were messaging on my post regarding GT sound. I have the same large stamped numbers (Drivers Res: C-9304-L, Pass Res: C-9408-R and C-9367 on the muffler). so i wonder if I have the same problem as you. I have cold start and WOT videos that sound very similar to your truck, I jsut can't figure out how to post them here.
Drivers Res:
Pass Res:
Muffler (there is an ingraved number but doesn't seem to be a part number just above the C-9367 "0851 1 258 21 C"):
Where did you find the stamped part number?
I'm interested in adding the GT exhaust to my Limited. Is it a straight/simple order from MOPAR or the dealer?Finally got the GT exhaust installed today on my 22 Limited. Its has the perfect sound for me, quiet in the cabin when cruising and aggressive when you get on. I attempted to install myself in the garage with air suspension set at its highest and rear tires on ramps, removed the spare tire and heat shield and its was a complete failure, I simply did not have enough clearance to maneuver the exhaust out. I put it all back together and took it to a shop and was installed in 26 minutes. Thanks to everyone on this thread whom previously installed this exhaust and posted here about it, it really helped me make the right decision. Now looking for a deal on 5" tips.
Yes.I'm interested in adding the GT exhaust to my Limited. Is it a straight/simple order from MOPAR or the dealer?
and its bolt on, easy installI'm interested in adding the GT exhaust to my Limited. Is it a straight/simple order from MOPAR or the dealer?
My buddy is in dealer sales...sold me my truck... said he would give me employee pricing on MOPAR stuff. This is encouraging to hear I could maybe save some cash as welland its bolt on, easy install
thats even better go for itMy buddy is in dealer sales...sold me my truck... said he would give me employee pricing on MOPAR stuff. This is encouraging to hear I could maybe save some cash as well
Is it difficult to detach the RH Tailpipe/Resonator from the muffler without doing damage to it? I'm asking because I want to install a resonator delete pipe (RH side) just to see if it makes a difference in sound.Yup. I find myself posting the pic of my GT exhaust on the delivery skid often. Looks EXACTLY like the stock exhaust. Only way to tell is by looking at the numbers.
It's very easy to detach it all.Is it difficult to detach the RH Tailpipe/Resonator from the muffler without doing damage to it? I'm asking because I want to install a resonator delete pipe (RH side) just to see if it makes a difference in sound.
Should be easy enough since it’s a slip fit and clamp.Is it difficult to detach the RH Tailpipe/Resonator from the muffler without doing damage to it? I'm asking because I want to install a resonator delete pipe (RH side) just to see if it makes a difference in sound.
Did getting the GT exhaust work out easily? I’m looking to get it as well for my non-GT but looks like you posted the same P# for both partsUpdate. Ordered these for my 23 non-GT Rebel.
68517364aa (muffler and driver resonator)
68517364aa (passenger resonator)
Both resonators were the same on the stock non-GT exhaust as the GT exhaust ordered, C-9408-L/R. The part number for the stock non-GT muffler was C-9367. The part number of the GT exhaust muffler ordered was C-9396.
So in my case, I did not need to order the passenger side piece.
But I’m very happy with the swap.
