Mopar’s “Ram Airflow” Cold-Air Intake System For Ram 1500:
Adrianp89
It's been a few years now and I don't want to read 1200 posts. What is the general consensus on this? Look cool/sound cool/open up some room? Any noticeable gains anywhere?
Still too expensive, IMO, looks good, maybe a little different sound, but s good exhaust will be better if you want sound. I'd still take my Vararam over the Mopar one at half the price, and a more old school Mopar look, if looks are what you are going for. Especially at car shows where the classic car guys will appreciate the classic look over plastic covers.
It does open room on passenger side of engine bay.
Adrianp89
Re-confirmed my thoughts from years ago lol. If it somehow got much better MPGs I would be in. I like the quietness of my truck, and performance is saved for other cars.
WXman
Kentucky, USA
$1k for no power gains and a mod nobody sees except the guys who change your oil? Do what??
RAM Patriot
Clayton GA
It does not add that much horsepower but, as the amount of fuel increases in Air-Fuel mixture, the temperature of mixture after burning of fuel is more. For same clearance volume in engine, higher temperature gives higher pressure inside the cylinder. Higher the pressure inside the cylinder above the piston, more force will act on piston giving higher torque.
Vararam claims to add up to 30HP +35-40lbs of torque and 1-2mpg.
WXman
Kentucky, USA
Yeah, more air equals more fuel. There will never be a fuel economy increase when you start dumping more air into the engine.
At the end of the day the throttle body, intake runners, and valves can only take in so much CFM of air. If you want 40 lb/ft you're going to have to mod the internals.
Technically, when at WOT, the PCM is running in open loop using preset values for fuel and spark. It only uses IAT and coolant temp to adjust. O2 sensors are ignored. So if you are getting more air into the motor, it will slightly lean out the fuel. And since the factory tune is set rich for "safety" it is very possible to add HP on the dyno. Daily driving at part throttle, not going to make a difference. I dropped 3 tenths off my 0-60 time going from stock to my Vararam intake. Tested same day, same road, three runs in each configuration to get an average. That increase in performance did not carry over to my times at the drag strip though
ferraiolo1
North Central PA
That's why it says "adds up to 30 HP".
They coulda said “up to 100”
Still doesn’t mean anything.
If adding a intake would add that much performance and mpg. Then ram would have added it from the factory to increase their epa and performance numbers.
All they do is make your engine bay cooler and your wallet lighter.
crusher
st-jean quebec canada
... Then ram would have added it from the factory to increase their epa and performance numbers.
so if it makes are wallet lighter.... then they do give you better mpg... by shaving weight ahahaha
Not necessarily true. There is a reason the RamAir intake doesn't have a CARB EO number to be sold in California.
CalvinC
Colorado
Like Gieco's claim... you could save up to 15% or more..... So wait, what are you promising me, exactly??
mikeru82
The Palouse
That's true, but they know that even the gullible people wouldn't believe that claim. I'm sure they went with 30 to try and maintain some semblance of reality to people who don't know enough to know better.
But you can buy a GT model in CA, which comes with this intake from the factory. No?
I'm not sure on that. I wonder if the GT models aren't sent to the accessories building to have the RamAir installed like they do for the running boards, spray in bed liner and tonneau covers before being shipped to dealers. Those aren't installed on assembly line
Detroitmikeb
So I’ve had the Mopar CAI on for about 50 miles. It sounds great but there’s such a lag in the lower RPM’s now. Like you punch it from a stop, it’s a dog then shoots up to 3k and roars.
I’m really hoping it’s just the computer relearning (unplugged the battery for 2+ hours during install).
