Nope, the repin adapter is included in your picture.Hi guys I am new at this I have the same situation I bought a module from 2500 It came with the screen and update cable my question is do I have to still repin
Cab Net ICS integrated center stack = Disabled.Thanks for the info
Now i need how to change it in the bcm can you point me in the right direction .
From my reading you are the men to speak with again I'm new at this .
I just did it last week and I have same setup as you.Please advise if this has been asked . I have 2019 1500 (new body) with 8” non nav system. Level 2 alpine system. Looking to purchase 12” and upgrade . I’ve seen several n eBay approx pricing 6-700 up to 12-1600. Part I’m unsure about is are some of these screen sold without the model/brain which is needed or are they usually sold with what’s needed ( electronically ) ?
2nd can someone provide short list of items I’d need for the upgrade . So far I’m aware of alfaobd only for programming . I really appreciate any help given .
 drive.google.com
					drive.google.com
				I can send what you need.This has most of the information you need. Should this be sticky?
Posted by @theRamguy and information by @Jimmy07
ALFAOBD - Google Drive
drive.google.com
Not sure if any of the documents have the part numbers of the 8 pin connectors and terminals for the repin harness
Female connector- https://www.digikey.com/products/en?keywords=307001081
Female connector terminals (5)- https://www.digikey.com/product-det...amp-connectors/1393366-1/A101883CT-ND/2700940
Male connector- https://www.digikey.com/products/en?keywords=309681081
Male connector terminals (5)- https://www.digikey.com/product-det...tors/2-1419158-5/17-2-1419158-5CT-ND/11492481
Send me a pmAnyone know the correct part number for the 12" Bighorn Bezel? Seeing different part numbers for bezels and of course all mopar sites just show the diagram and not the actual bezel. Looking for that bighorn marble finish at the top of the bezel
 But now I'm going to update the software, can someone tell me what software is better to put on my 2019 bighorn, the latest 39.9 or is there a more stable one?
 But now I'm going to update the software, can someone tell me what software is better to put on my 2019 bighorn, the latest 39.9 or is there a more stable one?Post 2091 google drive, has step by step if yours is uax 39.9 is the newestI just finished installing the 12” screen, I want to say a big thank you to everyone who helped here and shared their experience! Most of the answers are easy to find through the searchBut now I'm going to update the firmware, can someone tell me the update manual via usb? And what firmware is better to put on my 2019 bighorn, the latest or is there a more stable one?
Thanks, will try.Post 2091 google drive, has step by step if yours is uax 39.9 is the newest
Thanks for posting that as I am sure it will help. Can you tell us where the best place is to get these parts? Do you remember part numbers by chance?I just did it last week and I have same setup as you.
You need:
Screen (and bezel)
Media Module
LVDS Cable
Jumper Cable Connects from Back of 12" screen, is either black or grey and connects to your existing 8.4 small harness
ALfa to program
Security code for media module if it's not new
Thats "it"
Did you get the part number for the Bighorn bezel? If so can you share it?I was just running the part numbers and they all do say they will work with mine minus the bezel. Thanks!
