spaniel43
- Aug 2, 2020
I had deleted the S10 before pairing the S22. When originally paired the S22 worked! Taking a little more time, again! I just found that the uconnect setting that mirrors the phone to the trucks screen had been turned off. Everything is back to working order as it was when originally paired.Did you delete the S10 from the uConnect? If the s10 worked, then the S22 should also work. Get a new S22 and tell them, (Provider) that the USB is not working.
Sent from my SM-S901U1 using Tapatalk
