I
I'd be curious how much shorter they would need to be to sit under the factory bracket. I really appreciate the feedback and you taking the time to let us know. Your solution definitely worked as well.@Shifts And Grins Fab Here are a few photos from under my truck. I focused on the passenger side since I couldn’t get a wide enough angle but the driver side is the exact same. View attachment 117669 View attachment 117670 View attachment 117671
So to elaborate, the top holes being used were already there on both sides, I had to drill the bottom holes. In order to fit the Diode Dynamics light bar which is 31.5 inches total with the brackets this way I had to flip them around to make them wider. And since the brackets are not perfectly symmetrical I had to put the driver bracket on passenger side and vice versa, otherwise the light bar would have been sitting to low in the grille for most of the light to shoot out. As you can see the bumper support bracket hits the light bar brackets and stop them from going any wider ( which is why I had to flip, and then swap the brackets around. ) actually in the photo you can see the bottom right corner of the bracket is sitting behind the bumper support bracket, that’s where it contacted on the bottom. The top side is to tall to slide under the curving bumper bracket so it’s just sitting flush against it.
If the brackets were just slightly shorter, I may have been able to use the two bolts of that bumper support bracket but I’m not sure if they would line up with the light bar bracket holes, I thought about cutting the brackets shorter to go that route but that seemed like a lot of work lol.
I’m pretty happy with the brackets themselves, seems like I could mount a pretty heavy light bar to em and never have to worry about it. Also including the 4 bolts in the box was awesome, saved me a trip to Home Depot!
Im happy to take measurements or answer any more questions, thanks for making these!
