I have a BigHorn. Do I have the active air dam? I thought all the trims did....Ive only owned the truck for 2 weeks so not very knowledgeable on it.What trim is your truck? I don't think anyone has done a video of the replacing the lower grill but I don't think it is difficult either. If you have the active air dam you will remove the two bolts on the support bracket for active air dam and slide our brackets underneath it and reinstall the factory bolts. Let me know if you have any questions during the installation.
I have a 30" single row bar ready to go in. Had the same bar mounted on my Tacoma. It got some moisture in it and got warrantied, but never got it reinstalled before trading it in. I was very happy with the extra light before. Not sure if the Rams halogen highs are weak, or Im just so used to extra lights on the front. In addition to the 30" lightbar, I had a pair of 7" spots behind my grill. All hooked up to the high beams.
Im doing basically the same setup I did on my last truck as it worked so well. Having it on a separate switch on the dash somewhere makes it harder to turn on/off for traffic and whatnot. I figure if I need the extra light of a lightbar, I need my high beams already. I do not have auto high beams so didn't consider that, but it could definitely play in for those that do.It seems not that many connect it to the high beams (but I can be wrong), but that is what I want to have (or to do) too.
I bought the RC wifi remote so I can put it on and off when outside of the truck but I hope I can also hook it up to the high beams, cause otherwise you will hardly use it while driving.
I only wonder with the automatic high beams how blinding it will be when traffic signs or other items reflect back to me![]()
As others mentioned, you'll have to look underneath your truck to see if you have the active air dam or not but the brackets and light will work just fine either way.I have a BigHorn. Do I have the active air dam? I thought all the trims did....Ive only owned the truck for 2 weeks so not very knowledgeable on it.
We have tweaked and updated the design so now you don't need to do that. Yo will remove the two bolts on the active air dam bracket that bolt to the bumper support and slip our bracket underneath. You will then reinstall the factory bolts. Here are some photos showing that:I have a 2019 Laramie, So if i'm understanding this right I may have to flip my brackets to get the bar to sit center? They are not the newest revision but they are from the prior style. Just trying to paint that picture. As i'm about to do the suspension and new tires and I was planning to install this as well. As I have been sitting on the brackets for a good bit and my Trigger4 kit for switches. I was just holding off until I got the oil filter relocation kit installed. And that's done now so ready for the fun stuff.
I understand they are redesigned. But the ones I have are not the newest revision.. they are the older style. So I was just trying to clarify what was needed to get this mounted up.We have tweaked and updated the design so now you don't need to do that. Yo will remove the two bolts on the active air dam bracket that bolt to the bumper support and slip our bracket underneath. You will then reinstall the factory bolts. Here are some photos showing that:
Once you remove the grill and line up the brackets it’s pretty easy to see which way they need to go
