Marvelousdude2500
- Aug 21, 2021
Without having to stick my head under the dash this time, do you know what side of the connector is the aux wire connected to?If you’re referring to the wires in the switch bank connector I referenced in the linked post below, your truck already has those six wires populated, and they terminate at a connector at the driver footwell.
Is there a blunt cut wire on the opposite?
If i make my own wires, do I need a male or female terminal to insert?
Thanks Jimmy07.
