Upfitter Switches
I have been making these Switch Panels to replace the overhead Sunglass Cubby.
Fresh Print of my Switch Panel with PSI Display:
Switch Panel Wiring:
Red Fused Battery Wire goes to the Power Switch for the BED. So it works with out the truck being on for camping.
Orange ACC 12V power to the rest of the Switches, the constant LEDs, and the PSI Guage.
Black Ground Wire goes to two connections on each Switch and to the PSI Guage.
The Red/Black/Green wires go to the Pressure Sensor
Gray Wire goes to the AUX Fuel Xfer Pump
Green Wire Goes to the Front LED Driving Lights Relay
White wire goes to the Reverse LED Pod Lights/Relay
Yellow Wire Goes to the Bed/Cap Relay
Blue Wire goes to the Air Compressor Relay
Violet Wire goes to the Air Horn Selenoid
Mounted in Overhead Console on Desk:
Mounted in Truck:
The Power Switch to the Bed/Cap I still need to order in the Contura III
square type. I still want to paint it with a light coat of Black. Then I just have to
do all the rest of the wiring runs.
Malodave
This is another members here that did a Carbon Fiber Vinyl Wrap to his. This one does not have the PSI Display like mine does.
image-jpg.94605
Malodave
@Malodave Bringing up an old post but can you supply the file for this? What do/would you charge?
I've FINALLY gotten around to making the fuse/relay box combo. I'll be finishing it all up in a few days and I'll add some more pictures and details for the box and relays I used (also using Delphi Metripak 280 style connectors, as it just makes it all easier.
All done, added my finished install pics to the how-to thread as well, turned out really good.
