That would be the center stack. Note there are two types:
68312620AF with lane assist and parking buttons at the top bezel
68420967AD with only hazards button at the top bezel
Thanks you
Did you have any issues with screen not coming on.
I did this exact procedure non Nav 8.4 to 12.1 Worked perfect with the correct cables of course. Added cellular antenna and wifi/bluetooth antenna. All works. Now if we can get a similar trick to get passive proximity entry to work.
What parts do I need to add the cellular antenna and the wifi antenna
68306857AA which is the wifi antenna. Also 68293977AA which is another cellular antenna. Then the 2 cables I think are 68402697AB and 68417547AA. You may need to double check and see if these cables are listed elsewhere on this site.
Hope these work better than the stock units. I have a hard time keeping an internet connection, but I believe that is mostly due to AT&T sucks where I live. That is the carrier used.
Can someone verify which bezel part number will match my 2019 Bighorn 1500 Crystal Met. 8.4 with Nav
I believe my parts list is
68317978AI Radio Module (source yet to be found)
68417577AA LVDS
68312620AF Screen
6MB16TX7AA Mat
Plus making up my own adaptor.
I have everything for Alpha OBD. I just finish passive entry a couple weeks back.
But I'm struggling with the correct Bezel, please see pictures below.
Is this 6UV463xLAB?
I would like to know if 6UV463xLAB is the part number for the 12'' bezel as well. I have Black / Diesel interior
Can anyone confirm this is the accurate part number?
That is correct it is the black/diesel bezel I just got it in couple of days ago.
Pictures from Mopar's database:
If anyone is looking for a cheap alternative to the pricy push nuts to install the module, I pick up these at Walmart. Cheap and hold the new module in securely.
Hey Guys new to the forum and also new to the Mopar family. I ordered a 2021 3500 Big Horn at the end of February and she should be getting delivered to the dealership hopefully within the next couple of weeks. I wanted to see if any of you who have completed the 12.1” radio swap couple help me by telling me if I have the correct parts in order to install them. The truck will be coming with the 8.4” non Nav display. This morning I ordered the radio module(68472388af) and the center stack(68425514ab). I know that I still have to order the instrument panel bezel which I don’t know the part number. My truck has the all black interior. Does anyone happen to that part number. Also the jumper cable that the mopar site is giving me that fits my truck is part #52112491AC. Besides these main pieces and the AlphaOBD + OBDLink. Is there anything else I’m missing?
How much are the OEM push nuts and would you happen to have a part number? TIA
Found them on eBay from 13-17 each. Local dealer said 14. 6034833 is what I had looked up. I don’t know 100% if they are exact, just going off pictures.
ok, thank you!
I installed the radio and I have no travel link app. I waited a week for it to pop up and is hasn't. Am I missing something? Or do I have to activate a feature for it to work?
Yes- ECUConfig 3: SDAR Travel Link Feature Present- YES
