Thanks youThat would be the center stack. Note there are two types:
68312620AF with lane assist and parking buttons at the top bezel
68420967AD with only hazards button at the top bezel
What parts do I need to add the cellular antenna and the wifi antennaDid you have any issues with screen not coming on.
I did this exact procedure non Nav 8.4 to 12.1 Worked perfect with the correct cables of course. Added cellular antenna and wifi/bluetooth antenna. All works. Now if we can get a similar trick to get passive proximity entry to work.
I would like to know if 6UV463xLAB is the part number for the 12'' bezel as well. I have Black / Diesel interiorCan someone verify which bezel part number will match my 2019 Bighorn 1500 Crystal Met. 8.4 with Nav
I believe my parts list is
68317978AI Radio Module (source yet to be found)
68417577AA LVDS
68312620AF Screen
6MB16TX7AA Mat
Plus making up my own adaptor.
I have everything for Alpha OBD. I just finish passive entry a couple weeks back.
But I'm struggling with the correct Bezel, please see pictures below.
Is this 6UV463xLAB?
That is correct it is the black/diesel bezel I just got it in couple of days ago.I would like to know if 6UV463xLAB is the part number for the 12'' bezel as well. I have Black / Diesel interior
Can anyone confirm this is the accurate part number?
Thank you very much. Ordering parts today.That is correct it is the black/diesel bezel I just got it in couple of days ago.
Anytime!Thank you very much. Ordering parts today.
I need the connectors how do I get them from you in have 8.5 non navdo you still have these?
How much are the OEM push nuts and would you happen to have a part number? TIAIf anyone is looking for a cheap alternative to the pricy push nuts to install the module, I pick up these at Walmart. Cheap and hold the new module in securely.![]()
ok, thank you!Found them on eBay from 13-17 each. Local dealer said 14. 6034833 is what I had looked up. I don’t know 100% if they are exact, just going off pictures.
Yes- ECUConfig 3: SDAR Travel Link Feature Present- YESI installed the radio and I have no travel link app. I waited a week for it to pop up and is hasn't. Am I missing something? Or do I have to activate a feature for it to work?
