2021 night edition third brake light
Just to clarify, are you saying if I currently have the auto-dim mirror on a 2019 Laramie that we just need the cable and the brake light assembly? Or is the factory auto dim mirror different than this new digital mirror?
If you already have the auto dim feature, the connection is the same exact thing. All you would need is that FAKRA cable which gets ran from the back of the CHMSL camera to the back of the second connector on the mirror. It’s full plug and play
@jdmdc5teg06
How is mirror brightness and video quality at night time, could brightness be a detraction? Any chance of posting addition pics and or videos?
You need the digital mirror part to see the CHMSL camera view...
What is the black nub, next to the LED light, on the side opposite the camera?
That I honestly do not know lol. I was trying to look it up but couldn’t find anything on it.
I'm wondering if it is where the cargo cam goes on the heavy duty trucks?
Is the HD CHMSL the same form/fit as the 1500 CHMSL? Could the HD part work here for us? Would be sweat to have the digital backup cam on the mirror and the analog cargo cam on the center console...
That would be awesome! The actual CHMSL from the HD doesn’t fit our 1500 DT’s. That’s why I was actually looking at that little piece to see if that’s a cover that can be removed to then purchase a separate camera for the cargo area
  • Like
Reactions: cj7
After looking at the front of this digital mirror, and seeing there is only one part number for it, just something to be aware of for everyone looking to do this- If you currently have an auto dim mirror, and you have auto high beams, but do NOT have adaptive cruise/FCW/lane keep assist, then you will lose the auto high beam feature by installing the digital mirror. This is because the digital mirror doesn’t have the auto high beam camera. Mirrors on trucks that do not have ACC/FCW have the auto high beam camera on them. Trucks that have ACC/FCW use the camera in the driver assist module next to the mirror for auto high beams.
If your vehicle comes with auto dim then yes. The screen doesn’t need to be activated on the whole time
And the camera comes on only when you put it in reverse or can you make it come on by pushing a button or something? This really could help me with my dark *** tint
Does the digital mirror work like a regular mirror when the camera/monitor is switched off? Or is it just dark?
When the digital mirror monitor is on, can you adjust brightness?
Yes to both. Although not as reflective as a normal mirror it is still a mirror and very usable. Brightness and focus position can both be controlled via the mirror.
Actually pretty neat. You can move the viewable area up and down via the mirror.
@Jimmy07 Any chance the other part of the tech package would be able to be retrofitted? (HUD) Im sure it would at least require AlfaOBD to be able to enable it, a new dash pad, the projector and then some film on the windhshield to properly display the image.
You also need the 2021 instrument cluster (because it has the USB port for the HUD module). You can’t buy a brand new instrument cluster from a mopar parts supplier, so you’d have to wait for a cluster out of a wrecked 2021.
